This is the answer.
It all has to do with how each has designed the 3PH geometry. Mainly, where the actual lift points are on the arm itself in relation to the ball ends, where the link hooks to the tractor, and its relation to 24" behind the ball ends.
I am bored so I'll give you an example.
First, so we are on the same page with the termonology. There are 3 points that come into play on the lower 3PH arm. They are the point where the arm is affixed to the tractor, the point at which the lift arm connects (usually about half way between the tractor and the ball end) and then the ball end.
So... lets say that the lower arm is exactally 24" long and the lift point is right in the middle @ 12". For a rating of 1000lbs @ the ball ends, this would require an actual lift @ the vertical lifting arm of 2000lbs. Using that actual lift force, this would give a 12/48 (or 1:4) ratio @ 24" back. Or 500lbs.
Second example, Lower arm is lengthened 6" and the actual lift point is still 12" back from the tractor. Giving 18" from the lift point to the ball end.
In order to maintain the 1000lb rating 2 the ball ends, this would require a lift force on the arm of 2500 lbs. Now @ 24", which is actually 54" away from the tractor, we now have a 12/54 ratio. Multiply that be the 2500 lbs and you have 555lb rating @ 24".
This is somewhat of a crude example of how two tractors can have the same or similar rating at one point and differ at another.
