Square bale Grapple and accumulator
   / Square bale Grapple and accumulator #1
blueriver
Super Member
S.E.Oklahoma
JD 5520 Montana 4340 Farmall Super A Montana 5720C
I just purchased the 10 bale grapple for delivery next week ... Does anyone have the plans to build the accumulator that fits the FEL?
   / Square bale Grapple and accumulator #2
Blueriver go to wrlong.com and check out his. He has one that is called a grapulator that does it all.:thumbsup:
   / Square bale Grapple and accumulator #3
I assume your FEL as a skid steer quick attach adapter on the ends of the arms. Here's the QA on my Mahindra 5525
I couldn't afford a store-bought accumulator-grapple, so I made my own. It's an 8-bale squeeze (2-twine small bales) with a detachable accumulator that
rides on the arms of the bale squeeze.
You can get an idea of the design of the accumulator from these photos.
The bale squeeze has a skid steer QA plate welded to its backside
The accumulator was pretty easy to build from rough sketches.
Thats correct and I did check them out ... however they accumulate, grapple, load but they DO NOT unload ... I needed the unloading as well.
   / Square bale Grapple and accumulator #5
Oh ok i didnt know you couldnt unload with it. :D
View attachment 185668View attachment 185669
View attachment 185670View attachment 185671
Yes I have the Skid Steer QA ... They want right at $10K for everything ... Like you I just can not justify that. So I elected to go with the 10 bale grapple and will be working on the 10 bale accumulator for the FEL in the shop this winter...
I went with the Rafter M 10 bale Grapple out of Texas ... he was running an off season special and saved a few hundred.
Yes per WR Long ...
This unit can accumulate, transport, and load square bale hay, however it does not unload if the owner chooses to tighten up the hay when he loads the trailer. In the video of the Grapalator on our website you will notice that the operator slides the hay toward the front of the trailer to help tighten the hay for transport, however since the gaps have been collapsed then the dividers of the Grapalator will not have room to go back down between the bales. If the operator sells most of his hay in the field or if the barn is to small to load then this is not an issue, otherwise a grapple will be needed.
   / Square bale Grapple and accumulator #8
I have about $1.5K invested in that homemade bale squeeze/accumulator- includes the steel, hydraulics and $125 from eBay for the skid steer attach plate that's welded to the back of the bale squeeze. It was a winter project several years ago.
I am interested to know more about the squeeze ... I couldn't see from the pic. I assume when your bales are acumulated in the buch of 8 bales then your machine "squeeze's" them to lift them ... how about unloading?
   / Square bale Grapple and accumulator #12
Situation: bales scattered over the hayfield--use the accumulator to gather bales in groups of eight. When this step is done, remove the accumulator from the squeeze (it's detachable) and pick up the bale groups one at a time and stack on transport device (generally a flatbed trailer). Once that's done, my job is over (I have no need for baled hay around my place--no animals to feed) so I don't get involved in unloading bales.
That photo I posted doesn't show the four brackets that are welded to the tops of the squeeze arms (two on each arm) to attach the accumulator.
Thanks ... clears that up.
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2013 Ford F-150...
2018 Isuzu FTR Landscape Dump Truck (A59230)
2018 Isuzu FTR...
2007 Ford E350 (A55973)
2007 Ford E350...
2004 AGCO Gleaner 3000 Corn Header (A56438)
2004 AGCO Gleaner...
2021 Delta Manufacturing 30ft 10-Ton T/A Gooseneck Flatbed Equipment Trailer (A55851)
2021 Delta...
2017 Ford F-250 (A55973)
2017 Ford F-250...
