540/1000 PTO as Economy PTO?
   / 540/1000 PTO as Economy PTO? #1
Zebrafive
Super Member
South West MI
John Deere 2030, John Deere 6415
If I put an adapter (1000 to 540) on my 1000 rpm PTO and run it at a lower rpm, would this work as an E-PTO? Or is this a dumb idea? Any thoughts?
I should note that my tractor shows the PTO rpm on the dash when the PTO is engaged. I have not checked at what engine rpm the the 1000 PTO would be running 540 rpm yet.
   / 540/1000 PTO as Economy PTO? #2
If you want to simulate an E-PTO at 540 RPM, you will need a different gear ratio conversion than 1000 to 540. With just that the engine will still require the same RPM for 540 as it did for 1000. It will instead require a ratio based on the engine RPM difference at E-PTO speed along with the 1000 to 540 ratio. Maybe this is what you meant and I just didn't interpret your question correctly. Either way just thought I would bring it up.
   / 540/1000 PTO as Economy PTO? #3
Zebrafive,
I suspect that this would work for only light duty tasks. The epto works using about a 30% reduction in engine rpms what you are considering is about a 50% reduction from your rated pto speed. This should approximate idle speed on most tractors, and roughly 20% of rated pto power.
   / 540/1000 PTO as Economy PTO? #4
Be careful of lugging the engine at high PTO loading.
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51406)
2015 MACK ELITE...
2011 Chevrolet Impala Sedan (A51694)
2011 Chevrolet...
2025 SDLANCH SDLD25 UNUSED Crawler Dumper (A53117)
2025 SDLANCH...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
2022 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2022 CHEVROLET...
