GRAVELY ROTARY PLOW
   / GRAVELY ROTARY PLOW #11
I have used a rotary plow. Something that doesn't look like it would work until you use one. I think these were made just to fit Gravely walk behind tractors and won't fit the riding tractors.
   / GRAVELY ROTARY PLOW #12
While the rotary plow can be used on a 4 wheeled Gravely, the cost for all the parts and pieces is prohibitive. You could buy one or more good 12hp two wheeled tractors for what the parts will cost.
Richard
   / GRAVELY ROTARY PLOW #13
Sod busting isn't a big deal with the rotary plow on a two wheeler. I plowed two good sized gardens this fall in preparation for spring. Not once did I even bruise myself. I pulled rocks over 14" long out. One rock was bigger than a basketball. I had to dig that one out as well as a couple of others. There were liternally several dozen rocks i pulled out of the two gardens. The trick to it is not to plow fast or deep at first. My 5665 was barely over an idle and in low-low. It just flipped those rocks over and onto the ground. THere were a few rocks it could not handle and it mosty bucked but didn't twist or yank as a rule. The buried PVC pipe that got wrapped around the plow was another matter.
I am not saying that bruising your ribs could not happen but it didn't happen to me and hasn't in all the years that I have been plowing. Maybe I have been using the rotary plow for far too many years and know that one has to be reactive to it....not proactive. Being proactive will usually mean fighting the machine. Just let it go. It will take care of itself. If it pulls to one side or the other consistently, then the angle of the plow needs to be tweaked. It does not matter if the tracor hits a rock and starts heading off in a differnet direction. That will get fixed later when you cultivate.
Anyway, here is a picture of a Gravely four wheeler with rotary plow.
   / GRAVELY ROTARY PLOW #14
Good post! I don't know how you found that old picture and got it on here but that's about as clear a picture of a rotary plow working that one could want.
   / GRAVELY ROTARY PLOW #15
I remembered that picture from an advertising booklet back when Gravely published it back about 1970. At the time I thought that the rotary plow mounted on a 4 wheeler was about as cool a thing as I ever saw. For years I lusted after a setup like that. Now that I am older and wiser I realize why it isn't a great idea. A far better setup is a 12 hp two wheeler. You can almost idle along and bust sod.
Anyway, once I found the PDF of the flyer at Old Gravelys, I took a screen shot of the picture, copied into MS paint, cropped it, saved it as a JPG and put it on my website. Not the best resolution, but it works.
For those that have never seen a rotary plow, it is likely the goofiest thing you ever saw. Even after seeing it in action, it really doesn't help in figuring out how it works. It is almost magical how it tills the soil. The principle behind the plow is actually fairly simple. What the spinning blades do is slice the earth into about 1/4" slices and then tosses it to one side. It cuts up the soil and sod into small bits and if you have the right soil, that is all you really need to do prior to planting. I prefer to take it one set further and cultivate the soil afterwards. With the right soil, you wind up with dirt that is so well prepared and fluffy that you literally sink to your ankles when you step in it.
   / GRAVELY ROTARY PLOW #16
Just about any attachment that can be put on a Gravely 2-wheeler can and was used on a Gravely 4-wheel L&GT of that time period.
   / GRAVELY ROTARY PLOW #17
That was my error. I shouldn't have made the statement that the rotary plow wouldn't fit the tractors with out researching it. I enjoy these Gravely posts. I presently own a 16-G. Before that a 8163-G. If anything happens to my 16-G I'll look for another good used Gravely.
   / GRAVELY ROTARY PLOW #18
Here is a picture of a plow set up for drilling holes.
in a slow tractor race
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
2025 Swict 78in Bucket Skid Steer Attachment (A53421)
2025 Swict 78in...
UNUSED RAYTREE RMRB72 - 72" POWER RAKE BUCKET (A54757)
UNUSED RAYTREE...
2012 JCB 930 ROUGH TERRAIN FORKLIFT (A52705)
2012 JCB 930 ROUGH...
