RoyJackson
Rest in Peace
- Joined
- Nov 17, 2001
- Messages
- 24,646
- Location
- Bethel, Vermont
- Tractor
- John Deere 4052R Cab,, Deere 855D UTV, Z920A Zero Turn Mower and assorted implements
I just had this welded up a few weeks ago, I bought a 52" atv blade and then the quick attach brackets. I'm anxious to see how well she does on the 2305. I know several people stated that small tractors like mine the snow wants to push you off to the side. So, that's why it's in the fixed straight position.
Problem is you'll run out of traction pretty quick and not have a good way to push it out off the way.
Rob's suggestion of adding weight is a good one...you'll get further, but sooner or later, the weight of the snow you're pushing will exceed your traction.
Size of the tractor (small or larger) doesn't beat physics. They all run out of traction sooner or later.
Even with my 4400 (about 4000-4500 lbs with loader and filled tires) will run out of traction (just as my 670 and 790 did). The advantage I have is the loader...I can just pick the snow up and dump it off the drive.
