6 Volt Gator, 12 volt TSC spray pump ?
   / 6 Volt Gator, 12 volt TSC spray pump ? #1
bcarwell
Gold Member
Austin, Texas
Kabota 7500DT
Hi folks, I got a TSC 25 gallon sprayer on sale and didn't realize it has a 12 VDC pump and my Gator electrical system is 6 VDC. Any suggestions how to make my sprayer pump work off the Gator system ? Or any suggestions on a replacement 6 VDC pump- model and source ? Tnx.
Bob
   / 6 Volt Gator, 12 volt TSC spray pump ? #2
Bob
I thought the gator's with the exception of the toy ones were all 12volt ... one just keeps finding out.
   / 6 Volt Gator, 12 volt TSC spray pump ? #3
You could pick up a 6 volt golf cart battery and wire it in series with the existing battery to power the pump. You'd need to charge it with a battery charger when it runs low.
   / 6 Volt Gator, 12 volt TSC spray pump ? #4
I thought so also? Curious what model and how old this Gator is.
   / 6 Volt Gator, 12 volt TSC spray pump ? #5
Well the sprayer is 12volt so he could just carry a 12 volt battery in the bed of the gator and recharge that when needed.
   / 6 Volt Gator, 12 volt TSC spray pump ? #7
Convert the Gator to 12v.
Buy a 2nd pump and run them in series at 6v apiece.
Buy a 6v pump.
Buy an up-converter to produce 12v from 6v.
Buy a new Gator.
6v battery is best idea. Charge it very few years.
   / 6 Volt Gator, 12 volt TSC spray pump ? #9
That would work, but the extra 6v battery would give you more run time between charges.
PT 1000 Gallon Supply Tank (A57149)
PT 1000 Gallon...
2020 CATERPILLAR 302.7D CR EXCAVATOR (A60429)
2020 CATERPILLAR...
4ft Mini Skid Quick Attach Rotary Cutter (A56438)
4ft Mini Skid...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A56438)
Neckover GL24-2-7K...
2001 FORD F-350 XL SUPER DUTY FLATBED TRUCK (A60430)
2001 FORD F-350 XL...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
