While all the discussion of FEL'rs I would like to take this opportunity to post this article on safety into this thread for any other viewers that might be misguided from the discussion of Front End Loaders and how the weight can or will effect the operation and handling of a tractor, Sorry for the lengthy article but I think all should read while considering the use of a "FEL"
especially with use of one on a Cut tractor,
Many people use front-end loaders to move heavy things, Use caution when hauling any heavy load on a front-end loader so that you avoid side overturns. It is extremely important that the size of the tractor and loader are matched properly to the size and weight of the load being handled.
Side overturns result from the change in the tractor's center of gravity due to the additional weight of the load.
Figure 3. The point marked "X" is the normal center of gravity with a front-end loader. As a large bale is added, the center of gravity moves to a point marked "Z". When the load is raised, the shift in center of gravity increases the chance of overturning. The point marked "O" is the center of gravity for the round bale.
The normal center of gravity with a front-end loader is at the point marked "X." When a large round bale is carried on the front-end loader close to the ground, the center of gravity moves forward, represented by point "Y." The point marked "O," or half the diameter or length of the bale, is the bale's center of gravity.
Some operators will carry the load high for improved visibility while driving. However, when the loader is raised as shown, the center of gravity moves to the point marked "Z," which is both forward and higher than the original center of gravity, "X." In the raised position, the tractor is less stable and the potential for side overturn increases.
Now visualize this tractor on a slope with two wheels on the downhill side and two wheels on uphill side. As the load is lifted, the center of gravity gets higher and the potential for the tractor to roll down the hill increases. The same phenomena is observed with a dump truck. Have you noticed that no dump truck operator will dump the truck on a side slope?
The chance of side overturns increases when carrying a load on the front-end loader, especially on slightly rough ground. Moving the center of gravity forward causes a transfer of weight from the rear wheels to the front, making it much easier to bounce a rear tire off the ground when passing over bumps or holes. Plus, the additional weight on the front tires may exceed the axle and tire load-carrying capacity.
A loss of traction occurs when weight is transferred from the rear tires during load handling. This can be a problem when moving loads up a slope or on wet soil. Loss of traction can result in a braking loss on all surfaces. Mounted front-end loaders should be used when the load is properly counter-balanced by adding weight to the rear of the tractor. This additional weight will bring the center of gravity back to the original center.
Another dangerous situation occurs when the loader is raised too high. Some people use the loader to move Bale rolls the load can roll down the loader arms onto the operator. If you handle a load with the front-end loader (use proper bale handling devices to keep the bales on the loader), keep the load as low as possible and move slowly. Loader attachments such as spears and grapple-forks minimize the risk of the bales rolling down the loader lift-arms.
Table 2. Front-End Loader Safety Tips.
Never walk or work under a raised loader.
Raise and lower loader arms slowly and steadily.
Allow for the extra length of the loader when making turns.
Be careful when handling loose or shiftable loads.
Never move or swing a load as long as people are in the work area.
Stay away from the outer edge when working along high banks and slopes.
Watch for overhead wires and obstacles when you raise the loader.
Carry the load low to the ground and watch for obstructions on the ground.
Always use the recommended amount of counterweight to ensure good stability. Add recommended wheel ballast or rear weight.
Operate the loader from the operator's seat only.
Move the wheels to the widest recommended settings to increase stability.
Do not lift or carry anyone on the loader, bucket or attachments.
Lower the loader when parking or servicing.
Assure all parked loaders are on a firm, level surface and all safety devices are engaged.
Visually check for hydraulic leaks and broken, missing or malfunctioning parts, then make necessary repairs.
Under pressure, escaping hydraulic oil can have sufficient force to penetrate the skin, causing serious personal injury. Injuries resulting from oil penetrating the skin are very difficult to treat. Use a piece of cardboard or paper to check for pinhole leaks.
Before disconnecting hydraulic lines, relieve all hydraulic pressure.
Be certain anyone operating the loader is aware of safe operating practices and potential hazards.
Extending the tines of a loader may look like a good way to solve the loading problem, but when this is done the tractor's center of gravity is moved forward. Extra stress is placed on the loader, the hydraulic system and tractor front end.
All tractors used to move heavy loads should have roll-over protective structures (ROPS). ROPS can either be a protective enclosed cab or a roll bar with a canopy.
Tractor operators should utilize the tractor seat belt at all times when operating the tractor, regardless of the task that is being done.
