Rotary Cutter Bush hog made by International World Agritech Co.??
   / Bush hog made by International World Agritech Co.?? #31
i have a 5ft. international world agritech bush hog. for about 7 years we have work it hard with no problems it has been the best and toughest bush hog we ever owned.i just broke one of the blades off.got on internet found out they have went out of business i found new blades and new bolts for blades at a co. called temco here in southern ohio. they keep them in stock.the new blades are a lot more heavy duty than the ones that came on it.they told me that orginal when they broke it was where they bolted on replacement blades have alot more metal where they bolt on.here was a older man there that told me that they were heavyer and they would hit harder cut a lot better.the price was $29.99 each for blades and $10.99 each for the bolt,washer.nut.i think that was a really good price.
   / Bush hog made by International World Agritech Co.?? #32
Thanks for the up date. Do you know if they carry gasket kits for the gear boxes? One of mine has a leak. Not sure where it is comming from. Also, do you have a phone number for this place so I could call? Thanks!
   / Bush hog made by International World Agritech Co.?? #33
There are only two seals (not gaskets). If it's dripping from the top, you've simply overfilled it. If it's dirty down the front, it's the input shaft seal. If it's dirty around the base - or dripping on the ground underneath - it's the output shaft seal.
Another problem with that transmission is the unvented fill plug. When used hard, the expanding air from the heated gear oil has no place to go. So it pushes past one or both seals. The solution is a vented fill plug. That was my problem, so I ended up with an output shaft seal that I don't need.
If I can still find it, you can have it for a fiver.
//greg//
   / Bush hog made by International World Agritech Co.?? #34
My boxes do have a vented plug. There is oil around the base of the box and mower deck. Can you get me their number to see if they have the seals please? Thanks!
   / Bush hog made by International World Agritech Co.?? #35
Same seal, input or output. It's a 40x54x7, click here. Part number on mine is 15810. You can have both of mine for a tenner, and $3 for postage.
//greg//
2009 IC Corporation PB105 School Bus (A55852)
2009 IC...
2020 Deere 50G (A53317)
2020 Deere 50G...
2024 HURRICANE GF480 - 48" ROTARY DRUM SCREEN (A52706)
2024 HURRICANE...
2018 JCB 507-42 7,000lbs Rough Terrain Telehandler (A53421)
2018 JCB 507-42...
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
2011 Chevrolet Malibu 2LT Sedan (A54815)
2011 Chevrolet...
