Oil & Fuel Oil leak
   / Oil leak
I agree with Jerry and/or the oil got around the bolt and you didn't get it all gone on the first cleaning. You are on top of this problem now and will watch this area like a hawk. At this point, that's the best thing you can do. Certainly, no oil should be coming out of the casting around the bolts if everything is normal.
BTW: :welcome: to TBN. I got involved in your problem and forgot my manners.:eek: As you can tell, it's a friendly and helpful group here. Feel free to ask all the questions you need. If I'm not mistaken, your tractor is a rare 2WD TC40A. Correct?
Yes Sir,
It is a 2wd TC40A. Now about it being rare, you know better than I. Thanks for the welcome and yes I surely do appreciate all the suggestions and hospitality.
Thanks again and I'll be reading for tractor tips and suggestions everyday! :thumbsup:
   / Oil leak #12
I wonder if that bolt hole is drilled clear through into the crankcase? If so the oil could be coming out around the bolt threads with a little positive crankcase pressure.
If you see it again, pull that bolt and stick a wire in there to see if it goes clear through. And if it does, put a little silicone on the threads when you re-install the bolt.
   / Oil leak
Well when I pulled the bolt out I took pictures, attached, of the casting around, I think it shows that the bolt doesnt go all the way through. I'll be keeping my eye on those bolts and hoping there aren't any cracks within that cavity.
   / Oil leak #14
Years ago I had a Kawasaki MC that leaked from a bolt. The shop said that the hole was drilled too deep and that it should not have been a wet hole. They put some thread sealer on the bolt and the bike ran fine for many miles with no leak. Just a thought.
   / Oil leak #15
Must be some porosity in the hole if it's not a leak from elsewhere. Do like Raspy says with a little silicone on the threads. You'll forget you ever saw it in a couple of months.
Jim
   / Oil leak
Hey thanks gentlemen,
Thats exactly what I did, I put some silicone and tightened her up.... If its something more serious I think it will reveal itself soon enough.
Eastbx
2005 Mitsubishi Lancer ES Sedan (A51694)
2005 Mitsubishi...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A52748)
2016 Ford F550 4x4...
1999 Volvo VN Truck, VIN # 4VA7BBJF9XN770848 (A51572)
1999 Volvo VN...
1993 HEIL TRAILER INTERNATIONAL FUEL TRANSPORT TRAILER (A52472)
1993 HEIL TRAILER...
2005 Hino 268 Truck, VIN # JHBNE8JTX51S10984 (A51572)
2005 Hino 268...
