best way to cut 16ga metal and 1 inch tubing
   / best way to cut 16ga metal and 1 inch tubing #21
   / best way to cut 16ga metal and 1 inch tubing #22
Definately use the thin cutoff wheel. The thin ones cut a lot better than the thicker grinder type wheels. They can be a lil pricy but they sure do pretty work and are a dream to use.
Don't go back n forth, go ahead and sink it and the cut will be a lot smoother and straighter, more of a factory look. And you may want to make your deeper tubing cuts first. The wheels wear out fast and then you can take the used smaller ones to cut the thin sheet metal.
I use the 6 inch ones from Fastenal, cost is 5.00 each. I try to save them for the must have jobs due to their cost but they are a joy to use.
   / best way to cut 16ga metal and 1 inch tubing #23
I think it took me longer to read three pages of replies than it would take the original poster to cut the 1" tubing. :D
   / best way to cut 16ga metal and 1 inch tubing #24
Don't go back n forth, go ahead and sink it and the cut will be a lot smoother and straighter, more of a factory look............................ The wheels wear out fast
That's why your wheels wear out fast. You're using too little of the disk edge to do the cutting.
   / best way to cut 16ga metal and 1 inch tubing #25
You realize the wheel spins right? The same amount of edge is used no matter what. The amount of pressure applied would chage how fast a wheel wears out.
YEA----project done, cut it with a 4 1/2 inch grinder, thin Dewalt wheel, clamped a 2X4 as a guide, didn't use up one $1.70 wheel, (but I did switch to a second wheel cause I needed more "reach")
Spent 10X longer contemplating this project than it took to just "get er done"
   / best way to cut 16ga metal and 1 inch tubing #27
Sounds like me, usually spend more time thinking about how to do than to actually just do it. :laughing:
2013 F-550 Bucket Truck (A53473)
2013 F-550 Bucket...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
AUCTION STARTS HERE @ 9AM (A51406)
AUCTION STARTS...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2011 Ford F-350 Enclosed Service Truck (A51692)
2011 Ford F-350...
2007 GMC Sierra (A50123)
2007 GMC Sierra...
