24-ft manlift implement for my loader
   / 24-ft manlift implement for my loader #1
dfkrug
Super Member
Santa Cruz Mtns, CA
05 Kioti CK30HST w/ Prairie Dog backhoe, XN08 mini-X
I have wanted to build one of these for a long time, and at last I
have completed it. I have already used it to trim some of my many trees,
and to lift and attach the last pieces of metal roofing to my new
wood shed. I have created a video of the new manlift in operation.....the
link is at the end of this thread.
I started with a Genie AWP24 manlift, which I purchased used (and non-
operational) from my local rental yard. These units are designed to be
pushed around manually, then they telescope vertically with up to 300
pounds in the basket. Outriggers are attached and leveled first. The
third picture is from the operator's manual.
These units are pretty unwieldy, weighing in at about 650 lb. There are
also 19, 30, and 36-foot versions that use more or less sections in the
telescoping boom.
My goal is to adapt this to the loader on my Kioti CK30 tractor.
   / 24-ft manlift implement for my loader #2
Is your plan to use your tractor to just move it around or are you thinking of raising your loader to get extra height? I think the extra height would be a bad idea unless you can extend the outriggers. If you just want an easy way to move it and to be able to move it on rough ground I think you have a great idea.
Does it use a hydraulic cylinder to raise itself? If so are you going to use your tractor's hydraulics to run it?
   / 24-ft manlift implement for my loader #3
Great idea!
You have put together some pretty well conceived and executed projects.
I have little doubt this one is equal.
I couldn't find the video you mentioned, love to see what you ended up with.
I once had a somewhat similar large homemade cable run manlift long ago purchased for a very extensive construction project. They can be worth their weight in gold. Sold it for far more than I paid when I was finished.
It was no easy task getting this home. It comes with forklift slots, but
they are set at the wrong spacing for my tractor forks. It is also quite
high as it sits in my truck. Fortunately, my boompole attachment to
my loader could reach and handle the weight. Unfortunately, this unit
would not stand up on its own on my slightly sloped paved parking area.
Naturally, it was raining during the unload process.
Anyway....first the disassembly and analysis. I got this for only $500, and
the hope was that it did not need total restoration. Well it did. This unit
needed so much work, I probably overpaid for it.
This unit was left outside for years, and rain got into the chains and
pulley axles, as well as all the many roller shafts.
Kudos to Genie/Terex for providing free downloads of the PDF ops and
service manuals. This is the model that all heavy equipment makers should
follow!
This is an amazing piece of engineering. How it works and how it comes
apart is NOT intuitive at all. (And I have spent a lifetime of taking things
apart!) A very long cylinder pushes on the 2nd of 5 telescoping stages,
which are linked by leaf chain, pulleys, and sequencing cables. The
service manual drawing shows the stages. In the 2nd image, you can see
a bottom view, after I have removed the support framework, drive, controls,
etc. Note the Nylatron rollers between each stage, and the blue plates
that anchor each pair of chains. The 3rd image is of a side view of the
telescoping assembly with the staging cables disconnected. An overhead
crane/hoist was absolutely required for this project.
I have rented the Genie cable-operated manual material lifts before, as
well as tried several kinds of hydraulic manlifts.
These Genie Arial Work Platforms sell for nearly $10K new, and there is
a used one on my local Craigs for $3800, but it is a 30-footer.
There is nothing like having the right tool for the job.
(CRAZYAL: all will be revealed over the next few days.)
   / 24-ft manlift implement for my loader #6
I am curious about why mount this to the loader. Wouldn't the 3PT be a more stable place?
The FEL has down pressure, which makes it much more stable. The
spacing between the boom arms is greater than the 3PH's inner supports,
too. I also want to leave my backhoe on at all times, and use its
outriggers to level the tractor side-to-side.
Stay tuned.
Here I am starting the disassembly of the telescoping stages.
After setting the assembly down flat, I removed the sequencing cables,
then pulled out the cylinder. The cylinder is almost 6 feet long
retracted, and about 10.5' extended. It has a 1 GPM piston-type
flow restrictor to control the retract speed without causing much
extend restriction. This is mounted to the base of the cylinder. The
cyl rod acts on the place marked with the yellow X in the 3rd photo.
So far, so good. Then I ran into my first major problem. The brackets
that hold the pulley axles to the boom sections are hex socket
head bolts (photos), recessed into the aluminum boom. They did not want
to come out, using single allen wrenches, or ratcheting socket wrenches.
I broke one trying. I soaked them for days in PB Blaster, and even tried
impact tools. The only thing that eventually worked was repeated
heating/cooling with a propane torch. There were 16 of these. It took
over a month of re-visiting this project to get then all out. In the
midst of this effort, I found that virtually all of the plastic rollers (4 per
section) had frozen up on their shafts. You can see why in the photo.
Water had invaded them and caused rust. This meant that once the
chains, pulleys, shafts, and cables were removed, I needed to use a
come-along to pull the sections apart. The rollers had become skids.
I ended up buying 16 new roller shafts, and 5 or 6 new rollers. I reused
all the nuts, washers, shims, and roller caps.
   / 24-ft manlift implement for my loader #9
Stay tuned.
That answers my question, was unaware of the backhoe. I'll be watching......
   / 24-ft manlift implement for my loader #10
As stated the outriggers are the most important part of the whole rig.
There needs to be a lot of engineering calculations involved on this contraption. These are designed to be used on a solid level surface. Venturing away from the LEVEL solid surface all bets are off.
Going up 24' attached temporarily to the tractor is sketchy at best. Remember the out riggers are designed for the max weight of a man ( I think they calculate 250lbs, ). Now if you attach this to a tractor you are now asking the out riggers to support a 250 lb, man, the lift, and not the tractor if things start to go south. It ain't gonna happen. The outriggers will fail like a cracker under the weight of a bowling ball.
The idea and concept is brilliant but unless you do it right, make sure you have your life insurance paid up.
1984 Trailmobile Enclosed Van Trailer (A55315)
1984 Trailmobile...
2023 HELI CPYD25C FORKLIFT (A58214)
2023 HELI CPYD25C...
2016 FREIGHTLINER CASCADIA (A58214)
2016 FREIGHTLINER...
2015V Chevrolet Equinox SUV (A53424)
2015V Chevrolet...
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A55315)
2021 Unverferth...
2017 Ford F-150 Crew Cab Pickup Truck (A54814)
2017 Ford F-150...
