rotary tiller depth & weight
   / rotary tiller depth & weight #1
Agrantina
West Tennessee
Kubota L3240 GST
I will be buying a tiller this year and I have a few question about tillers. I have noticed that some tillers have a working depth of 1-4 inches, others have 7 inches and some dont list it at all. Weight--some tillers are 690lbs for a 5ft one and others are 441lbs? I gues my two question are
1) Working depth- why the wide difference in depths- is this a single pass working depth rating?
2) For most attachments weight is a GOOD thing. Is this so for rotary tillers also? Does the weight make a difference in tillers?
AndyG
   / rotary tiller depth & weight #2
AndyG
In my case, the Tarter has a typo in the specs. Our Hawkline weighs 100 lbs more than the Tarter, Same working depth on both. Ken Sweet
   / rotary tiller depth & weight #3
   / rotary tiller depth & weight #4
AndyG
Working depth will most likely depend on the blades (how sharp they are), the soil conditions (from old pasture sod to previously-tilled sandy loam), the speed (how slow can you go), and adjustments of the 3ph.
Weight of the tiller will play some part too, so yes to "does it make a difference".
Much more to the equation than an ad just calling out a "working depth" on a sheet of paper, as it really doesn't mean a thing. IMO. :)
Thanks- That is what I am think on the working depth number.. KingK doesnt list a working depth number at all and I have used a 4ft one before and single SLOW pass it will dig 4-6 inches IMO....
   / rotary tiller depth & weight #6
Agrantina - What are you planned to use the tiller for? If you are planting crops and you have good soil structure I might suggest a soil spader as it aims to retain that structure. Rotary tillers unfortunately eliminate soil structure that has been built up. See spader video at ..... YouTube - Soil Spader for Incorporating from Vegetable Farmers and their Sustainable Tillage Practice .......Gary
Gary,
How much does a good spader cost, and who makes a good one?
Someone else mentioned this implement, but I'm not having much luck finding any information other than they are more in line with no-till methods than a roto-tiller.
(No Utube access here).
-Jim
   / rotary tiller depth & weight #7
Gary,
-Jim
Hi Jim - The following is the article that originally triggered my interest..... Product Review: Spaders . It lists Celli, Tortella, Gremagna, Sicma, & Falc in the article. However the youtube video I believe shows an Imants machine which I think seems to have the best product range and features. See Imants at rotary spader, soil preparation cultivation equipment: Imants. for info. They are listing Autrusa at the US distributor. .........Gary
I talked to a local guy yesterday and he was telling me that the weight on tillers really didnt matter much. The dept was also not that big a deal. Said after 1 to 2 passes most tillers would contiune digging deeper and deeeeeper if you let it down. His impression was more on the number of tines and reliability of the maker then anything else. He said "come on- how many times you going to use it 5-10 times a year?" It will at last you if thats all your going to use it for? Geeeee he was alot of help:)
AndyG
   / rotary tiller depth & weight #10
The only benefit I can see from a heavier tiller would be when you hit a fair-sized rock or other chunk of something it won't jump up as bad and leave a little hard ridge - especially if you use some sort of manual planter like I do with my Earthway. I just broke a new 1/2 acre last year - plowed, disced and then ran my Kubota tiller thru several times (with new tines), after a couple more years of working this spot it won't be a problem anymore.
I would agree with having more tines is better - my 5' Kubota has 36 tines total, but you better check availability and price of replacement tines if you plan to use it regularly. Kubota wanted right at $15 each for those 36 tines and when the tines are worn it will not till hardly at all. Luckily my local co-op found some aftermarket tines in Calif. for $8each. If you go looking at used tillers make sure the tines are not shaped like a clip-point knife blade or worse, a steak knife - most new tines are rectangular all the way out to the end and this is when they really till well and the deepest. When I bought my tiller last fall I was luckily at a dealer and he called Kubota to price the tines before I bought it so I could adjust my offer on it. He had just taken it in on trade and it was still hung on the back of the tractor and he was able to run it for me to look & listen for a slapping drive chain or bad bearing.
2001 JOHN DEERE 310G BACKHOE (A52705)
2001 JOHN DEERE...
UNUSED EINGP F10 - 10' WROUGHT IRON SITE FENCE (A54757)
UNUSED EINGP F10 -...
2018 Toro Workman GTX Electric Utility Cart (A54811)
2018 Toro Workman...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/nerve-alive-supplement-reviews-inspired-by-nervecalm-for-natural-nerv-1044754
https://www.accessn...
