A suggestion from the Pros, please.
   / A suggestion from the Pros, please.
Theory is it allows the metal, base and weld, to cool slower allowing the hydrogen time to release preventing underbead cracking. (Sometimes I amaze myself, remembered that from trade school LOL)
I find horizontal the worst, vertical, flat, overhead and horizontal from easiest to most difficult...Mike
I think I got my terminology screwed up. Maybe I meant flat. What is the difference between flat and horizontal?
One more question. I know that welding rods should be stored in a warm environment. I plan to use a wife rejected toaster oven. The lowest defrost mode may even be too high. Maybe a timer to go on an hour a day, or so...?
What you think?
   / A suggestion from the Pros, please. #12
I never considered a toaster oven for a rod box. Good thinking. The rods should be ok to 300 degrees or so. At least get them over 212. Happy welding.
   / A suggestion from the Pros, please. #13
Cellulose coated rods like 6010 should not be heated. KEEP them dry and they will work ok. They actually need about 80% humidity to weld right. IF they get too dry the fingernail on you. That means the flux burns off on one side faster than the other. E7018 should be stored at 250-350 F and rebake (exposed to moisture for more than 24 hours is above 500F if I remember correctly. You arent going to overheat them in a conventional oven thats for sure. One reason to preheat metal when welding with low hydrogen xx18 series (7018,8018, 10018 etc) is so you dry out the moisture that when welded over will sometimes produce hydrogen embrittlement or underbead cracking on the weld. This will lead to premature failure of the weld as once it starts to crack it keep going like a crack in your windshield. I would put a 30-37 degree bevel on both sides of your flat bar. If you have a copper bar,you could c-clamp it flat against the bar on the back side and use it for a backer bar(t he weld wont stick to the copper). Leave about an 1/8" gap with a 1/16" land or face as properly called. The face of the bevel is the point where the bevel meets the back side. If you had 0" face it would be a knife edge. You could also do it with 0 face and close the gap to 1/16" and use all 7018 rods. Grind out the slag before you weld on the back side If you used a single V bevel you would need to clamp the ends tightly to keep it from raising on one end as the weld contracts. I prefer to use a double vee which looks like an X when viewed from the end rather than a V (hence double v) As mentioned, weld a pass on one side then weld one on the other, keep doing this till the bevel is level full. There is no need to make the weld any more than flush with the parent metal as it doesnt get any stronger and may get weaker if you put too much metal on as it creates stress risers on the metal which act like a glass cutter mark on glass as it creates a weak spot for a fracture to start. Hope I havent been too confusing.
   / A suggestion from the Pros, please. #14
I stand corrected. Thanks for the input. I spent 6 years as a boilermaker (local 27). No experience with the cellulose coated rods. What are the advantages?
   / A suggestion from the Pros, please. #15
90 deg. Sorry, couldn't resist :D
Simple explanation, butt joint, lay two pieces of plate on the table with a gap between them, that's flat. Stick 'em to the wall with the gap going left to right, that's horizontal. Turn 'em so the gap is top to bottom, vertical. Back to the origonal table, turn it upside down and hang it from the ceiling, that's overhead.
A 'T' joint, (fillett weld) is a bit harder to explain, _|_ is a T joint, looking at the little diagram, if you weld it setting like it is, it's a horizontal fillett, the axis of the weld is at 45 deg.. If you turn it 45 deg. clockwise it's flat, you're basically welding in a trough, a 'V' formed by the two pieces. Same explanation follows thru for the rest of the positions.
Now pipe, that's a totally different kettle of fish. I won't get into that, 2G, 5G, 6G etc. It's been years since I did any pipe and I've forgotten most of the designations.....Mike
   / A suggestion from the Pros, please. #16
What you think?
I use a toaster oven, but only to recondition them. The Air Liquide brand rods I have (7018) call for 1 hour at 600-700 F to dry them, then 250-300 F for storage. I just dry them out, then vacuum seal them until I'm ready to use 'em.
I had to "fiddle" with the thermostat on the TO to get that kind of temperature, and it isn't something I'd recommend leaving to bake while you're out.
Sean
   / A suggestion from the Pros, please. #17
You could have used the Kenmore Pro oven I finally got them to take back without fiddling with the thermostat. It would get so hot that the ceramic coating on the liner melted above the heating element. Since that is basically glass, I guess that would be about 2400F.
I think you are on the right track though with backing them even if you only do it at the highest oven temperature of 500F or if you have a self cleaning oven, put it on self clean and try a batch. Then after cooling, vacuum seal them and they should be good forever if the seal isnt broken. May have to do this when the wife isnt home.
Nooooooowwww I know. I guess my preferred mode is "Flat". Thanks.
Great explanation. Easy to digest. Do the 6011 rods follow the same rule as the 6010?
   / A suggestion from the Pros, please. #20
I found this website that has a good reference to all types of welding rods and an explanation of the coding system for each one to help you figure out what the rod is useful for in terms of tensile strength, flux type and welding positions to be used.
http://www.welding-technology-machi...lassification-by-american-AWS-ASTM-system.htm
I also found this one for rod storage requirements which lists a goodly number of rods and their storage requirements of which 6010, 6011, 6013 all require dry non heated storage. Most other requires some form of heated storage after the hermetic seal is broken.
http://www.rodovens.com/welding_articles/storage_chart.htm
207282 (A52708)
207282 (A52708)
AEREATOR (A58214)
AEREATOR (A58214)
Brent 1082 Auger Wagon (A59814)
Brent 1082 Auger...
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
2008 DOOSAN G25 GENERATOR (A55745)
2008 DOOSAN G25...
Altoz 766 Zero Turn Mower (A59814)
Altoz 766 Zero...
