crazyal
Super Member
Here's a picture with the cap removed.
Did you remove the valve stem before you welded the pipe on? I would think you would half to or it would burn and leak real badly.
You did the welding with the tire mounted on the rim and the valve removed from the stem. Is this correct?
So then, I wonder what conditions it takes to get the results in those safety videos..........
I guess I dont understand, why are we all still trying to figure out some way to get around dismounting the tire.. why would you risk your life?
