New Wagon troubles
   / New Wagon troubles #11
Chopped some size off of them for the folks with dialup. :)
Ian
   / New Wagon troubles #12
Ian
All you need now Ian is a pair of restrain chains so it does not wander all over when backing.
   / New Wagon troubles #13
I'm not the OP. I just downsized his pics for public consumption.
Ian
   / New Wagon troubles #14
Another vote for a front hitch. I have two trucks with hitches on the front. Makes backing 4 wheel hay wagons a dream. I even drilled a hole in the end of one of my forks to push and pull wagons.
Dan
   / New Wagon troubles #15
Dan
The down side to pushing with the front of a truck is when the wagon is loaded, you can't see anything. Backing the wagon in with the truck allows you to use the mirrors that are out further and also keeps you further away so you can see more around the wagon then you can the other way. If the wagons empty its easy to back up as you just watch the back of the trailer.
   / New Wagon troubles #16
Backing it up will be good practice for learning to operate a backhoe. Equally difficult. Must have been the same inventor.
2012 Cadilac SRX SUV (A55758)
2012 Cadilac SRX...
2015 International WorkStar 7600 Tandem Dump Truck, VIN # 1HTGSSNT8FH507443 (A54865)
2015 International...
2007 Freightliner M2 106 Medium Duty Pac-Man RL10 10 CuYd Refuse Garbage Truck (A55852)
2007 Freightliner...
1985 International 1754 Material Spreader Dump Truck (A51692)
1985 International...
New Three Point Hitch Trailer Mover (A54865)
New Three Point...
Jeep Tailgate Themed Wall Decoration (A55758)
Jeep Tailgate...
