How to properly dispose of old LP tank?
   / How to properly dispose of old LP tank? #1
Richard
Super Member
Knoxville, TN
International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
I've got a 100lb propane tank. Took it to get filled the other day for the first time this winter.
Guy said the tank expired 2 months prior and they couldn't fill it.
Bummer for me because had I filled it in fall like I normally do it would be sitting full as a reserve tank to be used up at the end of winter.
So, be it as it may... now I have this expired tank.
Where does one properly dispose of this? I could see some places not wanting it for fear of it having some propane in it and exploding.
:confused:
   / How to properly dispose of old LP tank? #2
:confused:
Turn it into a BBQ pit. It would make a great one. If I lived closer i would come get it lol:thumbsup:
   / How to properly dispose of old LP tank? #3
You don't have to dispose of it, just get it recertified. They do a hydro test on the tank to make sure it doesn't leak and won't rupture, and the tank is good for years again. Any propane or welding supply outfit should be able to point you in the right direction.
   / How to properly dispose of old LP tank? #4
Apply lots of .223 and .308 from a safe distance, then crush with the tractor and haul to scrap yard. :D
   / How to properly dispose of old LP tank? #5
Recertification around here is only $1.00 and will certify it for 4 more years. A reputable propane place can recertify them within minutes. I have two that I was told will need recertification. Once done, they put a recertification label on it and you are good to go. Don't trash it unless they say it can't be recertified.
wow, I had NO clue about recertification!
I was preparing to replace them both (I've got two 100 lb tanks) and that would have been about $300.
Thanks!!
If they are recertifiable then I've just saved some cash and if they are not then I've lost nothing.
There is a major LP place downtown that could probably do it (other than the issue of carting this tank down their and having to borrow a truck)
:thumbsup:
   / How to properly dispose of old LP tank? #7
I suspect the $1.00 is if you refill it with their propane. :) Also, depending on the vintage of the tank, recertification may require testing that takes more than a few minutes.
Recertification is also a good time to refurbish the outside of the tank. Buff off the rust spots and give it a new coat of Rustoleum. If you turn it over and blow off the last bit of popane, it will vent any water that found its way into the tank. You have to turn it over to paint the bottom anyway.
   / How to properly dispose of old LP tank? #8
If it turns out to be no good simply open the valve & cut it off (preferably with a hacksaw, not a torch).
Along with BBQ grills I've seen thse welded together for culverts & garage chimneys.
Worse case scenario just paint "free" on it and leave it at the end of your driveway. It's worth a few dollars for scrap.
   / How to properly dispose of old LP tank? #9
Sometimes they will exchange it for another recertified tank and give you a freshly painted one or they will "refurbish" for a nominal fee as well. Failing all that, a large caliber tracer round through it when it is set on a beaver dam you want to remove is spectacular:thumbsup::thumbsup:
   / How to properly dispose of old LP tank? #10
I took my old tank to the local TSC on a Sunday morning and they exchanged it for a new one.
2009 Ford F-550 4x4 Ext. Cab Brush Fire Truck (A59230)
2009 Ford F-550...
207277 (A52708)
207277 (A52708)
2014 Ford Escape SUV (A55853)
2014 Ford Escape...
INTERNATIONAL EAGLE ROAD TRACTOR (A52707)
INTERNATIONAL...
Caterpillar 320 (A60462)
Caterpillar 320...
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
