Long-term storage problems
   / Long-term storage problems #1
Danica
Ulster County, NY
CNH TC40DA & Ford 1920
Hi, I hope this isn't a dumb question: due to divorce, I had to store *my* CNH TC40DA tractor for the last 16 months. I did have stabil put in the diesel fuel and filled the tank to the top. She is in a secure storage facility, completely away from the elements etc. If I were to go there in a couple months, could I assume that after 16 months in storage:
a) the battery is still ok?
b) the fuel is still good (it is in wisconsin which is cold)
c) the hoses etc will not deteriorate
d) the tires will be ok
Any advice would be greatly appreciated (bringing her back this spring when my new barn is done!!!).
Danica
   / Long-term storage problems #2
Live in SW Michigan and own several Kubota Diesel Engine powered tractors.
The lead-acid batteries like to be charged for maximum longevity - but not over charged.
Keep them all on a trickle charger with full charge sensining circuitry to self turnoff when the lead-acid is fully charged. (I paid $23.00 each for Sears units on sale). Can do better or worse. Check out Mills Fleet and Farm or Blainse Farm and Fleet there in WI. Can always check out Northern Tool too.
These Kubotas have mechanical fuel pumps and need to be primed when air bound. Not hard to do - but inconvienent. So modifing all with electric fuel pumps, which will self prime.
Diesel fuel degrades in warm temperatures - microbes- and gels in cold weather (not really as serious a problem if you do not try to start while gelled.
I use over the road diesel (because of all of the additives already in it - to avoid consumer complaints) and various over the counter diesel fuel additives and stabilizers. I rely on a good local tractor repair shop to supply me with the additional additatives.
   / Long-term storage problems #3
Danica
Usually the owners manual has the recommended procedures for storing a tractor long term. They include fogging oil for the cylinders , etc. But that's water under the bridge for you. Diesel fuel doesn't deteriorate like gas does and you were smart to fill the tank fully so there shouldn't be any water condensed in there. Didn't know Stabil could be use for diesel. I'd charge up the battery before I tried a start. If the fuel filters have drains on them you might open them to let out any possible water that was in them and reprime the fuel sytem. Then start it up and after about 2-3 minutes at idle, warm it up at about 1200 rpm til it starts to show some temperature on the gauge and put it to work. After you work it for a while(5-10 hrs) you might consider changing the engine oil.
As long as the tractor was storedout of the sunlight you don't have to worry about the tires and the fuel lines deteriorating.
   / Long-term storage problems #4
BATTERY! This will most likely need replaced. If left in the tractor it probably discharged over this time period. My thoughts on secure storage brings to mind a Lock and Store type garage. This provides shelter but cold weather will freeze a discharged battery. I would replace the battery and check all fluid levels before trying to start. Do not use starting fluid. Good Luck- you did what you could.
   / Long-term storage problems #5
It's all great advice. If the battery won't take a charge, replace it. The fuel should be ok. Tires and hoses would deteriorate the same if they are in a storage area, barn, or garage. Give them a quick visual for excessive cracking. I think you'll be fine.
Thank you all for the good advice! Unfortunately, there's no electric in the unit so no trickle charger possible. I figured I'd have to buy a new battery, for sure. That's probably $100 or so I suppose. Otherwise, I will look into what Jerry/MT said re draining water from the injectors (?) though that may be a bit beyond me. Yes, I topped it off at a truck stop so the diesel is probably the good kind and there is a diesel additive to prevent gelling and "improve" the fuel which i put in before i stored it. So thanks everyone!
   / Long-term storage problems #7
If the tractor was stored with a full tank of treated fuel and you didn't have fuel quality issues beforehand, chances are you won't have them now. The tractor will probably start after removing the battery cables, cleaning the posts and clamps, and jumpstarting it. Do check to be sure the battery hasn't fully discharged and the electrolyte hasn't frozen before attempting to charge or jumpstart. Exploding batteries are dangerous.
Save the battery purchase until you know that you need one.
   / Long-term storage problems #8
Not sure with your tractor but with my Kubota's they recommend locking the clutch pedal down for long term storage. There is even a hook near the pedal to do it although it could be done with a piece of wood or something. The idea is so the clutch plates do not freeze together during extended storage.
MarkV
   / Long-term storage problems #9
Guys, she said it's BEEN in storage for 16 months.
I would agree with everyting Rick stated. But I would expect to buy a new battery.
   / Long-term storage problems #10
I prefer to drain the whole system of fuel if it is to be stored for extended periods of time. Run the fuel in the lines out until it stalls. Leave a low point open.
Putting it back into service - requires filling and venting all the way through the fuel filter and injectors.
If no trickle charger - take the battery out - take it home - and put it on a trickle charger at the house. - same effect.
   / Long-term storage problems #11
On the fuel filter canister, there maybe a drain. That's what you should drain before start up. Don't drain the injectors. You'll need to prime the fuel system though and the instructions should be in your owners manual. If you don't have one see your dealer or look on eebay. Pull the battery out and take it home and charge it and reinstall. It ain't rocket science. Replace it only if it won't take a charge.
   / Long-term storage problems #12
- After the time this has been in storage, I would just plan for a new battery. Charge the battery before hand; verify what the battery manufacturer recomends.
- When you do go to start it, take it easy on the starter. If it does not start easy, only run the starter for a short time, then let it cool. That should be in the owners manual too.
- Those are the particulars I would concentrate on.
Once started, and back home, I would change the coolant(it gets acidic...). Just for good measure, I would also give it a complete filter/fluid change(oil, hydro, PS ect). Also grease all the fittings.
   / Long-term storage problems #13
Hey, here it is straight out of the manual, page 3-34...
Tractors which have been placed in storage should be completely serviced in the following manner before using:
1. Inflate the tires to recomended pressures and remove blocks(blocks should have been placed when put in storage)
2. Check the oil level in the crankcase, power steering resivor, common sump(for hydraulic lift, tranny, and rear axle), and the front axle.
3. Install a fully charged battery, and remover cover from exhaustShould been covered before storage)
4. Check cooling system for prpoer level
5. Start the engine and allow it to idle for a few minutes. Ensure the engine is recieving lubrication and that each control is functioning properly.
6. Drive the tractor without a load and check to make sure it is operating satifactorily.
Thank you thank you, guys!! The unfortunate thing is that the owner's manual and the really expensive, huge repair manuals are all in storage WITH the tractor!! :( I did not do all the things on the list, I'm afraid. But I did do many of them. Someone tried to scare me into a ridiculously low price for everything by telling me the hoses and all rubber stuff would deteriorate in a year and I'd have a useless piece of junk on my hand. I almost fell for it but my intuition told me this person was not exactly a benevolent "friend" but just looking to take advantage of the situation...
Thank you so much for all the good advice!
   / Long-term storage problems #15
Wow, a single lady with a tractor. If I wasn't already happily married I would ask you to send me a picture of the tractor :laughing:. Just kidding, it sounds like you have plenty of good advice here. If it was me I would take the battery home, charge it and take it back and try it. No need to replace something that isn't broken. Good luck.
CUTE! :) well, i've pretty much resigned myself to buying a new battery when i get there. It will have sat thru two cold wisco winters. i just cant imagine it has enuf power to start...
   / Long-term storage problems #17
I'm betting you wont have much of an issue getting it going again. I'd figure the battery is toast but other than that it shouldn't be hard to get running again. Dad bought an old Allis Chalmers that sat in the field 8 years prior to him buying it. He stuck a new battery in it & it fired right up and it ran for years.
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
2022 Ford F-450 Liftmoore 5000W Crane Service Truck (A59230)
2022 Ford F-450...
2018 CATERPILLAR 289D SKID STEER (A60429)
2018 CATERPILLAR...
2021 CATERPILLAR 259D3 SKID STEER (A60429)
2021 CATERPILLAR...
2024 CATERPILLAR 255 SKID STEER (A60429)
2024 CATERPILLAR...
CASE IH STEIGER 400 HD TRACTOR (A58375)
CASE IH STEIGER...
