Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #511
Tinman .. I love the look of that Bobcat box! Serious bit of metal. You'd think you'd need crawler treads.. and that tractor doesn't look heavy enough to handle a box full of wet snow? That's a big container...
Mine is simply a $300 Meyers Jeep plow on a frame-mount so I don't bugger my FEL. I can leave the FEL on and switch the tilt outlet to lift the plow. I can also push the snow, then pop the blade and bucket the piles..the plow frame remains in place. This was the very first time I used a front blade .. lots to learn.
Jim/Salisbury Maryland
   / Pictures of your snow weapons #512
Handling the Blizzard of Dec 2010... Southern NY. We got about 20"+ here with wind gusts up to 68mph! The little 2320 handled it well. Did 5 decent size driveways in about 4 hours without chains (thank you L/R braking). Some snow piles 8' or more!
   / Pictures of your snow weapons #513
Right JC, it is slow going with just a bucket. But eventually you get there, and hope you enjoy the great seat time. :)
With those winds, you just need to add the snowmobile helmet. :D
   / Pictures of your snow weapons #515
Didn't know a toboggan was i-Match compatible
   / Pictures of your snow weapons #517
We're out spreading anti-skid now using the big Agrex PTO spreader. So far it works GREAT! I mounted the optional remote flow control box inside the cab rather than out back and I can feather the rate of material spread just right. :thumbsup:
I highly recommend the Agrex cone spreader-just make sure you get the optional agitator and remote flow control. Few hundred extra bucks makes this attachment a pleasure to use. Takes a little while to mount the flow control valve, but now glad I did.
   / Pictures of your snow weapons #518
Good thing for JD tractors with big snowblowers and AWD cars...
Took this picture around the corner from my house after the blizzard. Now that is a big drift!
My father's new setup...
I think its safe to say that he is ready for snow
   / Pictures of your snow weapons #519
Builder,
I have a similar sized 3pt spreader, since you have much more snow experience than I have I would ask what you are using for antiskid material?
I was thinking of using coarse sand?
2003 International 7400 T/A Heil 12 Yard Dump Truck (A55852)
2003 International...
(INOP) CATERPILLAR 914G WHEEL LOADER (A52705)
(INOP) CATERPILLAR...
2017 FORD F250 SUPER DUTY EXT CAB SERVICE TRUCK (A53843)
2017 FORD F250...
2019 RBR Venturi 380 (A55301)
2019 RBR Venturi...
2021 WACKER NEUSON LIGHT TOWER (INOPERABLE) (A55745)
2021 WACKER NEUSON...
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
