Banging noise on my new B2789 snow blower
   / Banging noise on my new B2789 snow blower
You must be getting it to the point where the angle is too much for the u-joint on the PTO. Maybe you can rig something up to let you know where to stop lifting it when the PTO is running.
Good thought, crazyal, and in fact I believe I have a dial on the tractor to limit the height of the rear 3 point hitch, which I had already thought of using.
Case closed - thanks for the feedback TBNers!:thumbsup:
   / Banging noise on my new B2789 snow blower #22
sorry and i know this does not help but can someone tell me how to check the gearbox oil level on my b2789 snowblower? also how to i change it? there are no drain plugs? seems like a very strange deal! i do see a large bolt that looks like it goes into the side of the gear box but how you would fill it from there i have know idea. help please thanks guys!!
   / Banging noise on my new B2789 snow blower #23
i can lift my b2789 blower all the way up when it is running with no noise?? wonder why?
   / Banging noise on my new B2789 snow blower #25
About your blower;
I would check the snowblowers parts drawing to see if this is a filler port for the gear box as it is a splash lubrication system and the oil level should be below the lip of the bolt hole of if this is the filler hole
You should have allen plugs in the blower casting to drain it and fill it. you will have to wirebrush some paint off to see them.
You will need a small set of metric allen wrenchs and metric box end spanners/wrenches.
   / Banging noise on my new B2789 snow blower #26
no i have a b 2620 not a bx. and i looked all over for a filler port for the gear oil and there is nothing maybe i just fill if from that bolt in the side of the gearbox maybe i need to suck the old oil out?
   / Banging noise on my new B2789 snow blower #27
As was mentioned in an earlier post you might want to extend your top link a bit.
At the start of the season when I have the top link on my unit shortened up to build a base on the gravel,I get a banging at full lift. (BX 2200/60" Buhler/Allied)
When I reset the link for the rest of the season the noise is gone.
Dan
Dan
Hey, Dan, sounds like a potential solution. Will try it out.
   / Banging noise on my new B2789 snow blower #29
I would check with your dealer or "a" dealer about this as it should have a drain simply because the casting or machined parts has 2 pieces-if that fails call customer service at RAD in Canada.
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
John Deere 6430 Side Arm Tractor (A51573)
John Deere 6430...
2016 Toyota Prius Hatchback (A50324)
2016 Toyota Prius...
2020 Chevrolet Tahoe SUV (A50324)
2020 Chevrolet...
2001 KINCAID PRO-SERIES 1200V2 HYDRO SEEDER (A51406)
2001 KINCAID...
2013 Chevrolet Cruze Sedan (A50324)
2013 Chevrolet...
