My new Kubota with Air ride seat
   / My new Kubota with Air ride seat #1
DDT
Clay Center, Kansas
Kubota M6040/cab, BX25D, RTVX900
The seat in the L 5740 is to hard for my back, (surgrey- rods) My dealer found a Grammer air ride seat and a for/aft (Isolator) to fit my new work horse. I removed OEM seat and seat pan. I also got a seat pan from a M9540 tractor to add to make mine level.
After drilling a few holes I attached M seat pan and grammer seat and Isolator to OEM seat pan and put it in the tractor. Nice fit, this seat is a inch or 2 lower which helps the steering wheel placement to my knees and hands better.
I hooked up 12 volt to seat compressor and operator presents wires aswell. Added adjustable arm rests and adjustable head rest. Found out I could even get seat and back heater for it to.
This seat is wonderful.
I just dont under stand why Kubota does not offer a better quaility and air ride seat as an option, John Deere does.
This seat fits my back and bottom side so much better, the difference is night to day for me. Now I can stay in the saddle all day with out high pain levels. Thank You Grammer for making a good compact tractor seat.
I wish the Kubota Gods could see this and do some thing before I buy the next tractor.
   / My new Kubota with Air ride seat #3
I couldn't tell from the last photo, but do you have a way to support the front?
And don't forget to seal off the rest of the open area underneath, or cold air will enter the cab at that point.
Is it possible to leave the old pan on, and bolt the new one on top? That would be the best solution.
I did reuse the old seat pan and attached the new one on top of it. There are 6 OEM bolts that hold the pans in place so the seat is very soild.
   / My new Kubota with Air ride seat #5
Very nice install and looks comfortable.
   / My new Kubota with Air ride seat #6
I ordered my M85 w/ air ride seat as a factory option.
I don't understand why you couldn't get one.
E/S
   / My new Kubota with Air ride seat #7
Cool..........It was hard to tell from the pictures:thumbsup:
   / My new Kubota with Air ride seat #8
E/S
I don't remember seeing it as an option for the GLs (why not I'm not sure) but I also wasn't looking at cab models.
OK, Itook more pics with camera instead of my phone so you will see better.
I also got both tilt meters installed as well.
If anyone needs it.
seat, matrix cloth # A-MSG75GGRC
RH Arm rest # A-ARK6575RH
LH Arm rest # A-ARK6575LH
Backrest ext kit # A-BRK6575GRC
Seatbelt Kit # A-SBK6575LH
Fore/Aft Isolator - fits this seat, I do not have model # for it.
I spent about $1100 for all and my wonderful dealer let me have it at there cost, Hats off to Ravenscraft Imp.
I have allways found better deals at small dealers and they care.
207272 (A52708)
207272 (A52708)
2022 Coras Predator Steel End Dump Trailer (A56438)
2022 Coras...
1999 TRANSCRAFT FLAT BED 48FT TRAILER (A59575)
1999 TRANSCRAFT...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
2013 Ditch Witch XT855 Tracked Loader (A56436)
2013 Ditch Witch...
1770 (A58375)
1770 (A58375)
