Kubota L3800 HST 4x4
   / Kubota L3800 HST 4x4 #21
Is it better to have a smaller 4x4 tractor or a larger 2 wheel drive tractor. Say this tractor and a 50 HP two wheel drive. I guess it depends on what you use it for
Bingo!. Another thing is the type of ground you are running it on.. 2WD can work well on flat ground, but not as well on hilly terrain as a 4WD. also how wet, etc. On some places a 2WD would spend most of its time stuck. on others it is just fine.. a 50HP 2WD full size Utility tractor would usually be able to lift larger loads like a full size round bale, and safely pull a larger trailer due to larger frame size and weight, BUT all that said, most people would agree that a in general work a 30 HP 4WD CUT will out work it. Except for the things noted.. By the way welcome to this very very large group of people, and since it is so large there are about as many opinions as there are people:laughing:
All in all I think you/your dad have made a great purchase, and will get a lot of good out of that machine, and you will find uses for that front end loader you never even dreamed of. When you have hydraulic power at your fingertips, you start thinking in a different way. Use the search function of this forum to find anything you want to know, there are over 2 milllion post's here. and a lot of great guys. Have fun.
James K0UA
James K0UA
Thanks.
   / Kubota L3800 HST 4x4 #23
i to love my HST on my MX5100 4x4.when you start doing loader work youll love it even more.
   / Kubota L3800 HST 4x4 #24
Is hydrostatic good or bad?
:eek::eek::eek::eek::eek::eek::eek::eek::eek::eek::eek::eek::eek::eek::eek:
Do a search, find an easy chair and settle in for a long, long day or two of reading. We have both and bot have their place, I see neither as "better", just different.
Thank all y'all for the good information.
   / Kubota L3800 HST 4x4 #26
Why would you buy a tractor before even knowing if its the right size for your needs?? Thats crazier than being worried about the paint coming off around the inside of your hitch hole.
   / Kubota L3800 HST 4x4 #27
If a person doesn't have significant experience with tractors, it is really hard to know what size and how to equip it for a given acreage. Even experienced operators often differ on the "right tractor".
   / Kubota L3800 HST 4x4 #28
Yeah, I agree, but his DAD bought this one...Plus 2 wd with loader? How do you stop a 2wd with loader if the rear tires slip? Drop the load...JY.
Yes my dad just came home and told me he bought it i was not involved in buying it I'll just use it.
   / Kubota L3800 HST 4x4 #30
I saw this and about peed my pants laughing. I'm sorry but i have to agree with knightrider955, holy smokes....
2012 JACK COUNTY 130BBL VACUUM TRAILER (A52472)
2012 JACK COUNTY...
2015 FREIGHTLINER CASCADIA DAY CAB (A52577)
2015 FREIGHTLINER...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A52748)
Kubota SVL65-2...
2015 TAKEUCHI TB260 EXCAVATOR (A51246)
2015 TAKEUCHI...
