k0ua
Epic Contributor
Is it better to have a smaller 4x4 tractor or a larger 2 wheel drive tractor. Say this tractor and a 50 HP two wheel drive. I guess it depends on what you use it for
Bingo!. Another thing is the type of ground you are running it on.. 2WD can work well on flat ground, but not as well on hilly terrain as a 4WD. also how wet, etc. On some places a 2WD would spend most of its time stuck. on others it is just fine.. a 50HP 2WD full size Utility tractor would usually be able to lift larger loads like a full size round bale, and safely pull a larger trailer due to larger frame size and weight, BUT all that said, most people would agree that a in general work a 30 HP 4WD CUT will out work it. Except for the things noted.. By the way welcome to this very very large group of people, and since it is so large there are about as many opinions as there are people:laughing:
All in all I think you/your dad have made a great purchase, and will get a lot of good out of that machine, and you will find uses for that front end loader you never even dreamed of. When you have hydraulic power at your fingertips, you start thinking in a different way. Use the search function of this forum to find anything you want to know, there are over 2 milllion post's here. and a lot of great guys. Have fun.
James K0UA
