2006 TN75AA 4WD
   / 2006 TN75AA 4WD #1
rwk5412
Member
2003 New Holland 5610s
Trying to find a tractor that will run a batwing, 8ft hay cutter, round baler, and other smaller implements, roughly 300 acres.
I found the 06 TN75AA for about $14k with 915 hours and no loader. Any thoughts?
   / 2006 TN75AA 4WD #2
I have a 2003 TN75 and the only issue I have is the clearance under the tractor for the hay baler. I pull a 10 foot brush hog, 9 foot cutter, 10 foot disk and 4 bottom plow with no problems but the clearance is an issue with my 2wd.
   / 2006 TN75AA 4WD #3
thats a fair price on the tractor.but dont know what size baler youll be pulling with it.
   / 2006 TN75AA 4WD
In regards to clearance, are you referring to the winrow's when round baling? The one I found is a 4wd, does it have better clearance?
Well, the baler we have currently is an old Hesston that puts out around a 5" bale. In the future, we might get a little larger baler, maybe a 6'.
   / 2006 TN75AA 4WD #5
A TN75 isn't enough horse for a 5x6 round baler.
   / 2006 TN75AA 4WD #6
your going to need a min of 85hp to pull a 5 by 6 baler.
   / 2006 TN75AA 4WD
That's 85 PTO HP, not gross engine HP.
Actually, looking at a TL100 (90PTO) now instead.
After talking to a number of people though, it seems more and more people are moving away from the larger bales because of handling difficulty as well as being more difficult to transport on a trailer without hanging off the edge.
   / 2006 TN75AA 4WD #9
you move away from the bigger bales 2 things will happen.1 your cows will eat the lil bale real fast.we put out a 4 by 6 bale an our cows inhaled it in a days time.2if you bale 200 5by 6s a year.youll bale bale 250 4 by 6s.an youll double your hay needs.
   / 2006 TN75AA 4WD #10
A pound of hay weighs 16 ounces whether it is in a 4x5 package or a 5x6 package. If you store hay outdoors, the percentage of waste will be lower with the 5x6 due to less surface area per pound. Overwidth transport IS a problem in many areas and WILL NOT become less of a problem over time.
2002 JOHN DEERE 450H CRAWLER DOZER (A51406)
2002 JOHN DEERE...
2014 Chevrolet Tahoe SUV (A52377)
2014 Chevrolet...
Ryobi Sliding Compound Miter Saw (A51573)
Ryobi Sliding...
2018 Challenger 1042 Tractor (A53342)
2018 Challenger...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
