dcyrilc
Super Member
Rick,
That's a good idea that we can attempt if we can find the bottom end of the string in the hole cut through the 2x6 wall plate. There is no conduit, just a 1" hole cut through the bottom plate of the main floor wall (see the picture). From the basement, you can see the hole through the plate but the string is not visible.
However, the insulation workers went the extra mile. Apparently the workers pulled the string tight and cut it as close as possible to where it exits the hole in the 2x6 plate. After being cut, the string retreated up through the hole.
Obed
Again, I feel for you. For the ones under the windows, if the boxes are low enough you might be able to use an old metal coat hanger straightened out. Either go through the outlet box and feel/hunt for the hole in the plate or go through the plate and hunt for the outlet box. If you get through, you use plyers to pull a little extra, bend a tight loop and tape it shut so it doesn't snag insolation, then tie a new string to the hook and pull it back through.
For the taller ones, I've used the drill bits mentioned earlier but used the shaft end instead of the bit end and then taped the string to it. Still sucks.
