Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #541
These are all five of my snow weapons.
   / Pictures of your snow weapons #543
Yep, I used to break something every year pushing snow in revers with my 7' HD Woods blade. I would break my 6' LD Howse blade itself. Never nothing I could not weld up but pushing in reverse is the least desirable way but hey, its better then a shovel.:laughing:
Chris
   / Pictures of your snow weapons #544
Chris
Not if it is a shovel like ccsial has. :D
   / Pictures of your snow weapons #545
The only time I push in reverse is pushing the snow at the end of the driveway over the hill. Slow and easy since it's a 20 foot drop.
   / Pictures of your snow weapons #546
I'm curious about the pushing snow in reverse thing. My method has been to blow all but about 1" of snow (gravel drive) and then finish by pushing the snow with the back blade with the blade facing backward. I pretty much know where the hazards are and when the blade meets something, it goes up and over.
Anyone have problems doing it this way?
   / Pictures of your snow weapons #547
skywater
If just an inch of snow, I'd drive forward and pull the blade to remove that inch. Angle and reverse the blade as necessary to move the inch of snow away.
Pushing in reverse is the pits. :D
   / Pictures of your snow weapons #548
When I was using a rear blade, I pushed as you're describing. Just go at a sensible speed and you'll be fine. You will be pushing gravel (if your drive is gravel) on the lawn...that'll be part of Spring clean up.
   / Pictures of your snow weapons #550
Here's my poorman's plow, and it's storage spot.
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
2013 Nissan Rouge SUV (A53424)
2013 Nissan Rouge...
Forestry Truck Grapple and Frame (A55851)
Forestry Truck...
Caterpillar D6K LGP (A53317)
Caterpillar D6K...
2005 Ford F-150 Pickup Truck (A55852)
2005 Ford F-150...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
