What is the Best Radiator Flush?
   / What is the Best Radiator Flush? #1
belah
South Central Louisiana
Kubota M4030SU 1992
I have a 1992 model Kubota M4030su. I need to flush the radiator. Can someone with experience tell me what the best radiator flush would be to remove rust and other gunk? Also, do I need to back flush the radiator? Thanks!! Belah
   / What is the Best Radiator Flush? #2
I certainly dont know what the best would be but I do know that if you drain it then fill with a 1/4 cup of cascde dish washer detergent and clean water and run for a while with the cap off it will bring out an unbelievable amount of gunk and crap when drained, fill again with plain water, and run. Drain again and add your anti freeze mix.
   / What is the Best Radiator Flush? #3
Interesting, have you done it often?
Thanks Gordon Gourd, I think i'll try it.:thumbsup:
   / What is the Best Radiator Flush? #5
When I buy a used vehicle I will do it or when I think it should be done, which is not often. But it is easy. The stuff is right under the sink. And it does get out a lot of crap. Works in the dish washer with all kinds of metal utensils and pots. I do make sure I rinse it good.
   / What is the Best Radiator Flush? #6
Reading the service manual of my Kubota, which should be the same for you:
1. Cooling system should be cleaned on the following occasions:
-Every one year after service (should not have to if your using extended life coolant)
-When adding a significant amount
Cleaning:
-Kubota scale inhibitor or equivalent.
-follow instructions on bottle
   / What is the Best Radiator Flush? #7
   / What is the Best Radiator Flush? #8
   / What is the Best Radiator Flush? #9
AAAAAYYYYYYY CARAMBA LUCY, what have you done???!!!
For what its worth any water cooled engine will benefit from a radiator cooling liquid filter. and they work very well trapping a lot of junk.
   / What is the Best Radiator Flush? #10
At my truck parts store , I sell Permatex #80030 h.d. radiator cleaner . I also sell Cascade to the local Caterpillar dealer , they use it when a oil cooler leaks into a radiator .
2023 Chevrolet Tahoe FL SUV (A59231)
2023 Chevrolet...
24in pin on excavator tooth bucket (A56438)
24in pin on...
Crown Stand-On Electric Forklift (A59228)
Crown Stand-On...
2020 CATERPILLAR CB13 SMOOTH DBL DRUM ROLLER (A60429)
2020 CATERPILLAR...
2017 Chevrolet Express 2500 Cargo Van (A59230)
2017 Chevrolet...
2017 Toyota Camry Hybrid Sedan (A59231)
2017 Toyota Camry...
