thinking of turning rough land into farmland
   / thinking of turning rough land into farmland #11
* I would like to harvest the pine trees and make a little money off of them in the process...
Do you have other pine trees? from the photos, I don't see anything that's worth :2cents: maybe in 15-20 years. What's the diameter of the trees... you can call a forester in to see if there's enough to harvest.
I have cleared a lot of land like what you described. What I have found is that on trees up to 8" I can fairly easily knock them over with my TN65 which is a 52 horse tractor. If the tree doesn't want to go over I start digging witht he bucket at the base into the roots. It will then push over easier. Any tree that is too big to get pushed over will need an excavator to dig it out or you will want to leave it stand and farm around it. If you cut it off and leave the stump you will most likely find it with something you shouldn't. As for the small brush, I brush chopped it all down then plow it under with a 3 bottom, 14 inch plow. It will pull up the roots and the first two years are a hassle but what I do is as I plow, disc and cultimulch I keep stopping and picking up the larger root stumps. I plant the field into corn the first couple years as it allows me to keep working the ground and kill off the weeds and such with a couple years of good weed control on the corn ground. Around the third year almost all the roots are gone and the ground is smoothed out, weed free and the soil is in better shape as I do soil tests each year the first few years on any new field to build it up properly (then every other year after that). The third year I will plant it into a small grain unless I feel the need to plant it to hay right away. Planting it to a small grain allows me to use a different weed spray on it that helps eliminate any weeds that the spray program I use on corn ground may not have been as effective with. There isn't usually too much weed issue but it does help. Then after harvest I notill in the hay seed into the grain stubble unless there is an issue with the field where it needed to be plowed again.
It is a very fun project reclaiming farm ground. I have reclaimed around 75 acres over the last 10 years using my TN65 for most of it and a John Deere 450G dozer for a month to clear the heavily overgrown vineyards. One month with that dozer cleared a lot of ground and I only used it after work and on the weekends. I just dropped the blade at the end of the row and pushed all the posts, vines and wire in to the middle of the field and made huge piles and set them all on fire. The wires were the biggest challenge because of the tracks but its just a case where you have to pay attention. I could have done it all with my tractor but the dozer was a friends and didn't cost me a dime to use. I have since cleared 3 acres of vineyard with my tractor and that was more labor intensive as I had to pull the wire first, pop each post seperately with the loader then get everything off the ground so I can brush chop the vines before plowing. Its in its second year of corn now and the field is smoothing out nicely.
If you have a lot of large trees though I would look at renting a large excavator for a day or two as they can remove the biggest trees quickly and then you can take your time on the rest of the ground with your own equipment. I am almost done clearing land now though and only have to clear up the edges on a few of my existing fields to push back the woods that have been encroaching for a lot of years. Once their done this spring I will be sad as I will not have anymore to reclaim :( I really do love it :D
I thought about this post and other posts when I saw what was probably a scam on Craigslist.org. it was a 99 model year Cat tractor loader backhoe that weighed 19,000 pounds, 110 hp, and "ran well" and was offered for $2600. It did not have a telephone number, but only a button to communicate with the seller.
I agree, they are very small in this part of the property. I will have to call a forester to tell if they can use them for pulp wood. They are mostly too small for anything else.
   / thinking of turning rough land into farmland #14
I set up an appointment with the county forester, one of the first things I did after I bought my place. Definitely you should do that. He told me all kinds of things I didn't even know I needed to know.
   / thinking of turning rough land into farmland #15
Here's what we did.
1) Harvest the trees as desired.
2) Windrow the remaining trees & brush with a dozer w/brush blade (series of heavy vertical tines).
3) Plow with a disc plow as Ken Sweet says.
4) Burn off the windrows once they've dried, then disperse the dregs (dirt, ashes, etc).
The final cleanup took a few years but the fields were productive before the windrows were burned. Bear in mind that this was done in the 1950s.
   / thinking of turning rough land into farmland #16
Those trees aren't worth much, if anything at all. Maybe pulp, there's no lumber in them.
   / thinking of turning rough land into farmland #17
I think I would look into a grapple. Some brands have serrated lower tines that would work well to pull the roots and small stumps up and then you can pick them up and put them where you want easily.
   / thinking of turning rough land into farmland #18
[Those trees aren't worth much, if anything at all/QUOTE]
Might be surprised at what some mills will accept for lumber.:D
Look into a dozer with a root rake for after the Pine lumber trees are harvested. :thumbsup:
Or look into more horsepower and a heavy disk.:thumbsup:
I was looking at possibly row cropping, AFTER a clearing up the land. How big of a tractor would be needed to pull a heavy disk over it? When pulling the heavy disk over the pine tree roots (around 4,6,8 inches mostly in diameter), would it cut up the roots so that they rot faster, or would the disk pull them up out of the ground? I am thinking and dreaming of doing row cropping with a large tractor. Just keeping that in consideration.
For the root rake on the dozer, what would the root rake do? cut the roots up? pull the roots up out of hte ground? or both?
Thanks for the help.
These pictures were taken using an old fashioned kodak underwater camera that "expired" in 2002. Look how great the pictures came out. The last picture is my "1/3" mark, where it is 1/3 of the distance from one end to the other.
Unused 2025 CFG QK20R Mini Excavator (A50322)
Unused 2025 CFG...
2012 CHEVROLET 2500 HD SERVICE TRUCK (A51406)
2012 CHEVROLET...
2013 Toyota Prius Hatchback (A50324)
2013 Toyota Prius...
Horst Quick Tach Bucket (A52349)
Horst Quick Tach...
1996 JCB TELEHANDLER (A50322)
1996 JCB...
2004 EAST GENESIS TIPPER TRAILER (A52141)
2004 EAST GENESIS...
