School me on liquid filled tires
   / School me on liquid filled tires #31
I don't eat much for beets.......... so forgive me for being ignorant. Why doesn't beet juice freeze?
Also, my BIL has been tractor shopping. He claims he has run into a couple dealers use a citrus product for filling tires. Anyone farmiliar with the product? I assume it being so acidic that keeps it from freezing?
I thought about posting that link earlier today, but it doesn't answer the question.
   / School me on liquid filled tires #32
Rim Guard is freeze resistant to -35°F and will not solidify until -50°F.
   / School me on liquid filled tires #33
I guess it's some sort of scientific mystery............... :confused:
   / School me on liquid filled tires #34
Acidity & surgar content both depress freezing temp. Search for "freezing temperature of acid/syrup" fo scientific explanations. In fact almost everything soluable in water depresses freezing temperature. MikeD74t
   / School me on liquid filled tires #35
For the 3520 owners in the thread, here's the online manual:
OMLVU17926_J7
Scroll to the Ballasting Machine section and then to the Using Liquid Weight in Tires subsection.
I don't see any exclusion for the front tires, but something may have changed since the manual was published.
Spindifferent
   / School me on liquid filled tires #36
When my tractor was new the saleman offered to load the rear tires for free because I had purchased a loader with my JD, I declined because 90% of my operating hours was mowing and I didn't want to lug around all that excess weight when it was only going to benefit me 5% of the time, if that much. I have turfs and I never have had an instance where I felt loaded tires would actually improve traction that much. Stability with using the FEL, yes, traction, almost never.
Can anyone inform me, exactly what happens when you have a flat tire with liquid weight in the tires? I have had to plug about six or seven nail punctures in my front tires, have never had a rear tire puncture but if you do, what is the procedure one must follow to repair one that has liquid weight? Thanks.
   / School me on liquid filled tires #37
If you poke a hole in a loaded tire the goop leaks out. DAMHIKT.
   / School me on liquid filled tires #38
I was thinking if you turned the tire so the puncture was facing up that would stop the "goop" from leaking out, but wondered if those cement-and-plug type tire repairs would seal well with the liquid weight residue on the tire inside.
Also, on my older Deere 318, the owners manual cautions that using liquid weight in the tires requires an inner tube. I cannot imagine having to repair a leak on a rear tire filled with liquid weight inside a tube, the wheel/tire assembly would weigh a ton, you would end up draining all the liquid out of the tire so you could demount it from the rim and patch the tube, then reassemble everything and refill the tire...no thanks.
I hit a broken off T post and it punctured the rear tire and there was a small geyser of CC spraying out. I was about 50 yards from the barn, so I stopped, puncture at 12 o'clock and put a jack under the axle.
I was not there when the repair was made, so I do not know why all fluid was lost/not saved. They booted the tire and installed a new tube, but no fluid. Maybe the service truck was not equipped for fluid removal/installation.
Toro Mower (A50324)
Toro Mower (A50324)
2007 INTERNATIONAL MA025 (INOPERABLE) (A52472)
2007 INTERNATIONAL...
20ft Driveway Gate (A51573)
20ft Driveway Gate...
PLEASE VIEW ALL PICTURES!! (A50775)
PLEASE VIEW ALL...
2002 Wacker RD11A Tandem Smooth Drum Roller (A51691)
2002 Wacker RD11A...
2025 New/Unused LandHero 40 Gallon 2-Stage Air Compressor (A51573)
2025 New/Unused...
