L3010 Leak at allen screw on transmission
   / L3010 Leak at allen screw on transmission #1
okie350
Mounds Oklahoma
L3010 & BX2200
There is a small allen set screw on the bottom of the transmission. This screw seems to have a small hole drilled in it. I do not know if it is supposed to have this hole or not. But it is weeping what apprears to be hydraulic oil, not much, but will leave a quarter size stain on the shop floor over the corse of a week. like I said not much, but i CANT stand leaks.
I tried to tighten this allen screw but it was tight, that is when i noticed the hole in the center of the screw. what is tis allen screw for and why would it have a hole in it?
   / L3010 Leak at allen screw on transmission #2
The only thing that I have under mine is a six point plug with a hole. It is to drain water from the clutch housing. Of course mine is a manual tranny.
I have the hydrostatic transmission, I would guess this allen screw / bolt to be about 1/4" do you think it is a water drain plug?
Still trying to resolve this:confused2: anyone
   / L3010 Leak at allen screw on transmission #5
I have a GST L3710, but I looked anyway for you. Unfortunately, I don't see anything like you described. Just the weep hole with pin in the bell housing and the big trans/hydro drain plugs.
Sorry....
2012 International 4300 Reefer Truck (A53473)
2012 International...
2015 Ford F-350 Utility Flatbed Truck (A51691)
2015 Ford F-350...
2012 Altec WC126A Chipper S/A Trailer (A51691)
2012 Altec WC126A...
Toro Z Master 2000 Zero Turn Mower (A50324)
Toro Z Master 2000...
2017 Mack CHU613 Day Cab Truck Tractor (A53117)
2017 Mack CHU613...
