M Series-Convenience Hydraulic Lever
   / M Series-Convenience Hydraulic Lever #1
Turkeyman
Columbia, SC
JD 4720 and 5075M
It appears that some M series tractors have a rear hydraulic convenience lever for raising/lowering the 3 pt arms. Is this standard on cab tractors? or hydraulic shuttles?
Thank you
   / M Series-Convenience Hydraulic Lever #2
since your talking about a cab tractor.i think its pretty common to have a rear hydro lever to keep you from climbing in an out of the cab while hooking up equipment.but id ask your dealer to make sure.
   / M Series-Convenience Hydraulic Lever #3
I have a M9540 Grand Cab. It was not offered as an option when I bought mine 4 years ago.
I have seen this on other tractors and it does look convenient.
My solution is to open the back window and reach in to operate the controls.
If I had this as an option I would certainly get it but it would not be a deal breaker.
   / M Series-Convenience Hydraulic Lever #4
we kept the back window for that reason as well.
   / M Series-Convenience Hydraulic Lever #5
We have never used the 3-point on our M8540, but I don't believe it has this option. An open window and a piece of PVC pipe or my cane works on my L5030 HSTC.
I agree it would be handy though as mentioned not a deal breaker.
   / M Series-Convenience Hydraulic Lever #6
It wasn't an option that I know of, but would sure be a nice. I do like the PVC pipe through the back window idea.
E/S
   / M Series-Convenience Hydraulic Lever #7
E/S
That was one of the many tips given to me by TEXASJOHN.
   / M Series-Convenience Hydraulic Lever #8
I made a small bracket and bolted it to the bar that goes from side to side of the ROP. There is enough room to run 2 small rods under it and hook to the remote lever and the 3 point lever. Then you have control in the back!!
I used 1/4" rod and put a small knob on them. I only did it on my L4240, the B7800 doesn't need one.
   / M Series-Convenience Hydraulic Lever #9
That will not work with the cab in the way.
It would probably take a cable set-up to make it work.
Think I will stick with pipe & window method for now.
E/S
2006 Cadillac STS (A50324)
2006 Cadillac STS...
UNUSED AGT XZ20R EXCAVATOR (A51243)
UNUSED AGT XZ20R...
2022 CATERPILLAR 259D3 SKID STEER (A51242)
2022 CATERPILLAR...
UNUSED FUTURE SKID STEER 4IN1 COMBO BUCKET (A51244)
UNUSED FUTURE SKID...
