OP
deere5105
- Joined
- May 6, 2009
- Messages
- 1,086
- Location
- South Mississippi
- Tractor
- 2008 John Deere 5303 MFWD, 2004 John Deere 5205
If the 6' with smaller dia blades is cutting better than the 8' then I would say that the angle that the gangs are set at are not equal. As in the 6' is set at max angle and the 8' is much less. I don't think that anyone uses an offset disk for covering their seeded crop. An offset disk usually seems to cut deeper although that can be controlled with your position control and the angle of the gangs.
A tiller would give you the best seed bed I would think, but I don't know if that is really what you need. Steve (jenkinsph) is absolutely sold on tillers and I agree that a tiller does a wonderful job, just don't know if it needs to be that good for you.
If the areas that you are going to be doing are going to be done every year, I would go with a disk, the widest that you can comfortably move from point to point with your rig.
Good luck
I thought so too on the gang adjustment, but when I look at them they look about the same. The blades on the 8' unit have significantly more wear on them. I thought that might have some factor too. Your assessment of the seed bed is correct. The food plots are typically planted with a rye grass, wheat and oats mixture. The rye grass will grow on top of the ground for the most part. I do not require a premium seed bed for this. I also do not need to lose the ability to lightly cover. Helps speed things up to be able to use the one implement for both needs. In the garden I can make a couple of trips over it and drag it and end up with a suitable seed bed. We plant a few row crops such as sweet corn, beans and peas. I usually have a smaller spot for tomatoes, squash and such closer to the house to pick fresh. I am leaning toward the 22" serrated blade 3PT disk for the uses/needs I have. I will have to see how the 8' loads on my trailer. If it does well, that may be the route I go. We used a King Kutter tiller once to try to break up the yards for reseeding and seemed to take a long time versus running the disk through it. Thanks for the input from everyone.
