Row Hippers and Cultivator
   / Row Hippers and Cultivator
Yes, but his is a little different than yours.
His has 3 discs per side, the best way to explain it is that the inner discs do the hilling, the outer 2 discs do the digging to tear up weeds and work the tire tracks.
The inner disc must be at the inside edge of the tire tracks, otherwise you will be trying to move 'compacted' ground into a hill, and it won't work the greatest.
Thanks, that seems simple enough to do... But man, that's gonna leave some wide rows though..
   / Row Hippers and Cultivator #32
How wide are you inside your tires?
   / Row Hippers and Cultivator #34
The best way to explain it is this picture, the discs do the hilling, the tines do the weed removal between the rows, and work the tire tracks:
Here are a few pics of the tractor all the way around...
(I know it has a flat)
   / Row Hippers and Cultivator #36
Can't get a feel for the inside width of the tires, that will determine your row spacing. On a wide wheelbase tractor, you can get 2 rows between the wheels, but most smaller tractors you can only get one row.
Take bp fick's tractor for example, it has a higher horsepower, but is a narrow wheelbase tractor, and has narrow tires. Great tractor for tighter rows for gardening.
Your tractor also has narrow tires, but the inside tire spacing will determine your rows.(can't plant in the tire tracks).
When i take a measure, do I take it from center to center of rear tires, OR from inside to inside of rear tires?
   / Row Hippers and Cultivator #38
Also, it will depend on the crops being planted. They all need different spacing, from a couple feet apart for tomatoes, to less than a foot apart for carrots and onions.............but never ever plant onions and beans close to each other.
Look up gardening forums for some great info on this kind of stuff.
   / Row Hippers and Cultivator #39
Inside to inside.
Thanks!
2023 BOBCAT T770 SKID STEER (A52706)
2023 BOBCAT T770...
2021 Allmand Bros Maxi-Lite II Towable Light Tower (A52377)
2021 Allmand Bros...
RIGID 141 THREADER (A53843)
RIGID 141 THREADER...
2005 HACKNEY AND SONS, INC. BEVERAGE TRAILER (A53843)
2005 HACKNEY AND...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A52377)
2021 Ver-Mac...
2017 FREIGHTLINER M2 BOX TRUCK (A52141)
2017 FREIGHTLINER...
