Row Hippers and Cultivator
   / Row Hippers and Cultivator #51
One more bit of advice.................any site on the web that you go to, or any book that you might want to buy on gardening................
Go straight to the bean and onion section....................if they say to plant together..................burn the book, or blacklist the website.:thumbsup::thumbsup::thumbsup::thumbsup:
HAHA! You must have had a bad experience...
   / Row Hippers and Cultivator #54
Don't know if you found any yet.
DISCS
Too late for me, now my day's ruined. Thanks anyway tho, I'll bookmark Agrisupply. I bought the disks, shanks, knuckles, and bar, for $349. I'll get to kick myself till next spring now.
   / Row Hippers and Cultivator #55
Travis,
You asked how to figure row spacing.
The way my cultivator was set up was using the measurement from the rear tires mounted in their widest set. Measurement was c/c on the rear tires.Then 1/2 of that gives you the center of your tractor which is where your row is made so you straddle your row of plants.
Too keep from using a ruler, hitch your cult to tractor and stand behind it
you will be able to tell where your outside plows should go so they can plow out your tracks (locate in center of wheel).
Now on to the center for your row. The row will be in the center between your hitch arms directly below where your top link bracket is on the cult. The distance between these two plows (depending on the size of your sweeps or plow points or whatever you call them in your area, mine are about 4") will depend on what you are cultivating and what you are comfortable using not up rooting your plants (can be a big bummer). I think mine are set 14" c/c of the plow points.
The next set of tines should be set to where they will be mid way between the outer edge of your center plow point and the inner edge of your outside that is in the center of your rear wheel.
Just going from memory I think my plow points/sweeps are 4", 6", and 8".
8" being the plow that plows out the tracks and makes the middle. The 4" are the ones on each side of the plants. And the 6" of course are between the inside 2 and the outside 2.
These are called one row when cultivating but in my little mind they are only a half row when laying off the rows for the garden.
Hope this helps you some and that I didn't ramble on too much.
I think gardening was a little simpler when I used a mule and a couple different plow stocks and plow points. Been a while since I plowed with a mule.
David
Travis,
David
Thanks David. Yeah im gonna have to hook it up after I get my rows built and see what I need to do. Your information was very helpful andI'm sure I'll be coming back to re-read this.
Ive never plowed with a mule. That was WELL before my time...
If I can get the front tire to hold air long enough, and if the rain holds off, I might try to break the ground at my new garden spot tomorrow with the middlebuster.
   / Row Hippers and Cultivator #58
For corn, I like Bodacious, and Incredible...............for potatoes..........RED...........always red for best flavor red, red, red.
Did I stress RED enough?:laughing::laughing::laughing:
I hope you guys don't mind me jumping in a little late here. I agree with Don 87 Red potatoes:). Here's a picture us harvesting the last of our "RED" potatoes last November. These were planted July 1st and we still had a pretty good crop. I planted two 200 foot rows. Enough potatoes for us and many friends and neighbors for whole winter.
Question about the row hippers. Other than using for hilling potatoes what are the benefits for most other crops? I can see problems cultivating crops when planted on hills.
attachment.php
attachment.php
Jump right on in!:laughing:
I'll use a cultivator when the grass starts coming up in there. I'm really not sure if it's even possible to cultivate with row hippers (??)
I can't answer your question because I don't have any experience with gardening tools yet. I'm brand new to this.
I love that pic! I hope I can get as many taters as that! Wanna share any secrets??:D
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
2014 TEXAS PRIDE TRAILER (A53843)
2014 TEXAS PRIDE...
CASE INTERNATIONAL 695 TRACTOR (A51406)
CASE INTERNATIONAL...
2012 CATERPILLAR 316EL EXCAVATOR (A51406)
2012 CATERPILLAR...
2014 FORD F250 XL SUPER DUTY CREW CAB TRUCK (A51406)
2014 FORD F250 XL...
2017 INTERNATIONAL PROSTAR (A53843)
2017 INTERNATIONAL...
