Hyd / Trans oil for cold weather/ Ford 1900
   / Hyd / Trans oil for cold weather/ Ford 1900 #11
Uh no. I didn't explain in enough detail. The cheap oil comes in all types. Motor oil, auto trans, etc. This includes Hydraulic/Transmission oil for tractors. I just found it strange that we both used the stuff in our tractors and had the same cold weather problems. The f200 is $175 for an 18 litre pail at my dealership and that's just not do-able right now. Like I said, the regular stuff from the farm store just never gave me problems before so I think it may be this cheap oil. Could be moisture I guess. In any event, draining it all and cleaning the system, then using my old brand I'm sure will solve the problem. ( pretty sure )
If you are going to replace the fluid no matter what, but not want to spend much, look for a fluid that meets the Ford 134 spec, but is mulit-viscosity. Around here, the local Tractor Supply Co. (TSC) universal H/T fluid is 10w-30. It may not be as good as the F200 (but who knows) but it is likely better than the regular 134, at least as far as temperature range.
   / Hyd / Trans oil for cold weather/ Ford 1900 #12
, look for a fluid that meets the Ford 134 spec, but is mulit-viscosity. Around here, the local Tractor Supply Co. (TSC) universal H/T fluid is 10w-30. .
I have never hear of or seen multiviscosity UTHF.
Bill
   / Hyd / Trans oil for cold weather/ Ford 1900 #13
Bill
Multi-G 134D is exactly that. See below. . .
imageview.aspx
Spartan Pierce Foam Pumper Training Fire Truck (A51692)
Spartan Pierce...
2019 Chevrolet Equinox SUV (A51694)
2019 Chevrolet...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
(2) UNUSED 3500# DROP AXLES W/ BRAKES (A51247)
(2) UNUSED 3500#...
2019 Fecon BH74SS Hydraulic Mulcher High Flow Skid Steer Attachment (A51691)
2019 Fecon BH74SS...
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
