Hyd / Trans oil for cold weather/ Ford 1900
   / Hyd / Trans oil for cold weather/ Ford 1900 #11
Uh no. I didn't explain in enough detail. The cheap oil comes in all types. Motor oil, auto trans, etc. This includes Hydraulic/Transmission oil for tractors. I just found it strange that we both used the stuff in our tractors and had the same cold weather problems. The f200 is $175 for an 18 litre pail at my dealership and that's just not do-able right now. Like I said, the regular stuff from the farm store just never gave me problems before so I think it may be this cheap oil. Could be moisture I guess. In any event, draining it all and cleaning the system, then using my old brand I'm sure will solve the problem. ( pretty sure )
If you are going to replace the fluid no matter what, but not want to spend much, look for a fluid that meets the Ford 134 spec, but is mulit-viscosity. Around here, the local Tractor Supply Co. (TSC) universal H/T fluid is 10w-30. It may not be as good as the F200 (but who knows) but it is likely better than the regular 134, at least as far as temperature range.
   / Hyd / Trans oil for cold weather/ Ford 1900 #12
, look for a fluid that meets the Ford 134 spec, but is mulit-viscosity. Around here, the local Tractor Supply Co. (TSC) universal H/T fluid is 10w-30. .
I have never hear of or seen multiviscosity UTHF.
Bill
   / Hyd / Trans oil for cold weather/ Ford 1900 #13
Bill
Multi-G 134D is exactly that. See below. . .
imageview.aspx
2018 GMC 2500 4x4 Crew Cab (A52384)
2018 GMC 2500 4x4...
2003 Chevrolet Silverado 2500HD Pickup Truck (A53117)
2003 Chevrolet...
2019 CATERPILLAR 303E CR EXCAVATOR (A51246)
2019 CATERPILLAR...
2014 DIAMOND C TRAILER MFG. (A50322)
2014 DIAMOND C...
(8) DRAWER METAL TOOLBOX (A51248)
(8) DRAWER METAL...
