Ordered myself some Opti-lube XPD
   / Ordered myself some Opti-lube XPD #1
Haywire
Central Kentucky
Tractorless :(
After seeing how XPD did in that test compared to the Howes I bought, I decided to ditch it and buy some XPD. I emailed them and asked what the shelf life of it was, and they replied that there was no expiration if I kept it sealed and in a cool dry place (<75 deg). I ordered a gallon, which should treat 256 gallons. That should last me quite a few years. I was going to buy a couple quarts, but 2 quarts with shipping was $42, while a gallon was only $54.
I'll look up the original thread and post a link... Edit.. that sulfur thread is nearer the top than I thought.. here's the link to the additive study that Ken45101 posted.
Ian
   / Ordered myself some Opti-lube XPD #2
Been using it in my 02 dodge and my JD790 for about 2 yrs.
No complaints.
   / Ordered myself some Opti-lube XPD #3
Here's a link to the same test Haywire posted, but in PDF form. I find it's a little easier to read. :)
http://rivrdog.typepad.com/files/copy-of-diesel-fuel-additive-version-3.pdf
BTW, another product not listed in that test is made by Texas Refinery Corporation, their "DZL-PEP Artic". It has a HFRR score of about 413, so that puts it right up there just above the number three spot. Treat ratio is 1:1000.
Thanks MC... now if the person who made that PDF could spell insignifffficant, it would look more professional. ;) ;)
I wish they had included a random diesel purchase from a local retail pump to give an idea what the score of that is. It would vary of course from distributor to distributor but would give a general idea.
Ian
   / Ordered myself some Opti-lube XPD #5
Ian
Well they did get insignificant right 5 out of 9 times, is that significant?;)
I would love to see more random sample testing of the HFRR score on dispensed diesel...I suspect it is frequently worse than its supposed to be...:(
BTW that Opti-lube better be some good stuff at a $.21 a gallon treat cost. Bio-D (scored better on the lubricity test) at about a $.08 a gallon treatment cost....
$.21 a gallon wouldn't bother me on my fuel sipping Kubota, but I couldn't stand that on my diesel pickup..most of the time I'm towing in the 10-11 MPG range:2cents:
The hitch with the Bio is that it's only a lubricant, so some would still use an anti-gel, cetane booster and water disperser. You can get a bio mix at the pump here, but unless they're using that same soy based stuff for the mix, it won't have the same properties as what was tested.
Ian
   / Ordered myself some Opti-lube XPD #7
if a person were to add say 1.5 times recommended amt/ unit of fuel, (ie on a product like Howes) would the lubricity increase or stay same? Increased ratio (according to Howes) does no damage....just thinking aloud. bb
Can't speak for Howes, but I think Opti-Lube says there is no added benefit by using more than the recommended amount.
   / Ordered myself some Opti-lube XPD #9
Another thing with the Bio is you can't find it as a additive, or at least I couldn't.
I did get a gallon jug of 'Bio' from a guy I work with that makes his own from recycled restaurant cooking oil. Don't know if it's even considered bio in the lines with what were talking about.
I gave it a try anyway and it didn't seem to quiet my injector pump like the Opti.
My little Kubota is the only diesel I own. I want to buy a 3/4t diesel PU and a 10k trailer for firewooding, but according to my calculations, that will be 7 more years.... after mortgage is done and after child support stops. I don't want a good used one, I want a brand spanky new one.
Ian
   / Ordered myself some Opti-lube XPD #11
Haywire, have no fear the new trucks then,{7 years}, will be totaly different from what is available now.Diesels are going thru a morph now to clean up the exhaust...More than likely a lot better fuel economy will be there. Jy.
Got it in today. Came with a pump to put on the gallon and two graduated containers, a 16oz squeeze type that dispenses one ounce at a time and smaller 6oz container without the squeeze function.
Ian
   / Ordered myself some Opti-lube XPD #13
a pump to put on the gallon////smaller 6oz container without the squeeze function.
This is the combo I use, although my smaller container says 8oz.
Any hoot, I got the small container marked at the 5oz level and that treats the 20 gallons I get for the truck. Makes it real simple.
The stuff really stinks so your going to want to keep it off ya.
I guess it is 8oz... I was looking at the graduations on the side and they stop at 6. The label says "up to 8oz" in the tiny print at the bottom. It required my reading glasses to decipher. I think I'm gonna throw it away. I hate stuff that reminds me of my middle-agedness. :)
Ian
   / Ordered myself some Opti-lube XPD #15
Just got done ordering another jug.
Noticed their summer blend cost more than the winter, but the winter stuff has more stuff in it ? :confused2:
   / Ordered myself some Opti-lube XPD #16
2012 Ford E-350 Enclosed Service Van (A59230)
2012 Ford E-350...
UNKNOWN  500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
2012 Mini Cooper Coupe (A59231)
2012 Mini Cooper...
1985 John Deere 540B Skidder (A56438)
1985 John Deere...
2003 INTERNATIONAL 9900I (INOPERABLE) (A58214)
2003 INTERNATIONAL...
large capacity skid steer bucket (A56857)
large capacity...
