RTV 900 curtis plow
   / RTV 900 curtis plow #21
Timswi,
I'll look into TSC and see what they have. Thanks for the help.
Randy
   / RTV 900 curtis plow #22
Timswi,
Randy
Good luck at TSC...Nice thing about this is that nothing is really messed up from OEM. If you don't like it, the drill holes in the cutting edge won't bother anything.
I've plowed 11 driveways and a 700' right of way at least 6 times this winter and no issues with this set up.
It won't scrape off ice or packed snow, but that's the price you pay for minimal damage. If you get the snow early, this isn't an issue.
If you do this, I want pictures too:D
   / RTV 900 curtis plow #23
timswi,here is my short list,dash[no lights],should have turn signals[my BX does],when cold hard to get in and out of gear,hand throttle ,snow plow items as mentioned before.
Agreed on the dash lights although this isn't a problem on my 1100. The ambient light is kinda ok.
Turn signal: Fully agree, my BX has them too and 4 ways. Why not on this?
In and out of gear is certainly more difficult with the plow attached. I've figured out how to get around this. Without the plow, I have no issues.
I don't have a hand thottle, just a "fast idle" knob. Don't really use it for anything beyond warm up.
Granted, there are some things that they could improve on. Wish they'd ask the owners. They really don't.
All and all I'm happy except for the $19k I paid for it. I'm over that now though, I think.:eek:
   / RTV 900 curtis plow #24
Good luck at TSC..
Mine won't move ice or packed snow now. Looks great and I think I'll look into doing the same thing. I do 5 long drives 3 of which are a quarter mile long and gravel. It would help on those also. Great idea.
   / RTV 900 curtis plow #25
Coot:
Sounds like this will work for you...good luck with it and let be know how it works out.
Like I said before, be prepared to wipe out some drill bits going through the cutting edge.
Beyond that this is simple...I'm all about simple:cool:
   / RTV 900 curtis plow #26
I finally got to use my curtis plow. Wow it works great. The rtv 900 can move some snow! The only problem I have now is I can't get it out of gear when plowing...pisses me off always something. I have to shut it off everytime..sucks
I have a relief valve on my 2006 RTV 900.You can also press down on the brake pedal for a few seconds to relieve pressure and it should slide into gear easier.coobie
   / RTV 900 curtis plow #27
I had a place (michigan iron & equipment)located in Morrice Mi give my curtis snow plow a few upgrades,beefier shoes,1/2 cutting edge,and rework to whole lift/angle mounting system to full hydro.Works great now.coobie
   / RTV 900 curtis plow #28
Coobie, we need pictures as proof. :laughing::laughing::laughing:
I went all hydro as well. And will eventually put in a 3 spool to replace the existing 1 spool. 1-dump box 2-plow lift 3-left/right or rear auxiliary. :licking:
   / RTV 900 curtis plow #29
Hey does anybody know if the curtis blade I bought for my rtv900 will work with my kubota 2350 tractor? Just curious.
   / RTV 900 curtis plow #30
Xterra,
My guess is that you will have to get the welder out and build some attachment brackets. Not hard if you have a place to bolt a plate to and then fabs the mounts on it like I had my welder do.
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50774)
WE DO NOT...
2018 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
2008 Ford F-250 4x4 Knapheide Service Truck with Liftgate (A51692)
2008 Ford F-250...
2007 GMC W4500 Landscape Dump Truck (A50323)
2007 GMC W4500...
1991 Grove RT740B 40-Ton Rough-Terrain Crane (A51691)
1991 Grove RT740B...
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50322)
2018 Taylor-Dunn...
