How to get unstuck from snowbank?
   / How to get unstuck from snowbank? #1
Ken P
Member
North Granby, CT
Kubota B2410
Folks -
I managed to get my Kubota B2410 stuck in a snowbank of sorts today, dug it out with a shovel, but have seen a number of mentions of using the BH to get unstuck, and was wondering if someone wouldn't mind describing this for a newbie.
What I was doing was to snowblow a path around the house, which I've been doing with each snowfall this winter. It makes it easier for my dogs, especially our older girl Roberta, to get around outside. (We've had a pretty good amount of snow this year - for CT, anyway - and there's a crust which sometimes holds them up, and sometimes doesn't, so it can be hard for the old girl).
Anyhow, the path starts and ends at our driveway, which I'd already cleared. As I was just getting back to the driveway, the tractor slid a bit sideways so it was into the snowbank next to the path, and then it was stuck. I was in 4wd. I tried using the differential lock, but the tractor moved even less with that engaged (without it I could rock it a bit), which seems odd to me.
By the time I gave up trying to move, there was snow and ice packed in around and underneath. I dug around the wheels, then tried to get out as much of the stuff packed in underneath as I could, then lifted the front end of the tractor up by pushing the blower down, cleared some more, and was then able to rock the tractor a bit and drive out. All the while, I'm looking at the backhoe and wondering if I should somehow be using that to maybe lift the rear and move it over a bit?
Anyhow - if there was an easier way to use the tractor to get itself out, my back would love to know for next time. :D
Thanks -
Ken
   / How to get unstuck from snowbank? #2
I got stuck about 3 times when turning to the side to dump FEL's full of snow in last winter's big dump on us. For 2 of these, I was able to lower the FEL with its leading edge down. Then I just curled it up with a gentle simulataneous push on the "rear" pedal of the HST. On one of these, it didn't work. I had to dig away some snow.
Other times, just using the diff lock worked to get me unstuck.
Ralph
   / How to get unstuck from snowbank? #3
Folks -
By the time I gave up trying to move, there was snow and ice packed in around and underneath. I dug around the wheels, then tried to get out as much of the stuff packed in underneath as I could, then lifted the front end of the tractor up by pushing the blower down, cleared some more, and was then able to rock the tractor a bit and drive out. All the while, I'm looking at the backhoe and wondering if I should somehow be using that to maybe lift the rear and move it over a bit?Anyhow - if there was an easier way to use the tractor to get itself out, my back would love to know for next time. :D
Thanks -
Ken
I think you answered your own question. Or use it as a claw or a pusher however you can get a grip. Just be careful and move slowly.
   / How to get unstuck from snowbank? #4
To get unstuck from a snow bank with a BH, all you have to do is put it down to lift the tractor and "walk" the tractor forward.
   / How to get unstuck from snowbank? #5
That often works. You can also use the BH as a hydraulic come-along if there is a tree or something nearby to put a chain around. Extend the digger arm, attach chain to tree and BH bucket, then pull the tractor toward the tree using the BH hydraulics.
Dave.
   / How to get unstuck from snowbank? #6
If you're even stucker, sometimes you can push with the dipper stick while dumping with the front bucket curl to get your fronts out. I never did it in snow, but in the muck it works like magic sometimes. Just be careful and leave your out-riggers partially out there if you're lifting/pushing with the BH, it gets tippy.
   / How to get unstuck from snowbank? #8
I have gotten a backhoe unstuck from mid many times by pushing and pulling with the FEL and the BH many times. I watched my dad walk a hoe over 100 yards through a muddy farm field when he installing tile ditch.
Will
   / How to get unstuck from snowbank? #9
Should be able to set the hoe over with the BH also sometimes just outing the hoe out a bit shifts the weight to the rare enough to get a bite.
I get it now. I had only thought of using the BH to lift the rear, and wasn't entirely sure what I would do after that.
Thanks all.
Ken
2019 Toyota Rav4 LE Hybrid AWD SUV (A55853)
2019 Toyota Rav4...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A55315)
2023 New Holland...
Black Steel Diamond Plate (A55758)
Black Steel...
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
More info coming soon! (A55787)
More info coming...
Set of 4 12-16.5 Bobcat Wheels and Tires (A56857)
Set of 4 12-16.5...
