How much does a round bale weigh?
/ How much does a round bale weigh? #1
MrP
Gold Member
Central Florida
None: Sold Kubota L3410 HST 4WD
I just unloaded one from the back of my truck. I was wondering if the weight could be too much for my FEL?
The round bale is about 6 feet in diameter and 6 feet wide.
Any guesses?
/ How much does a round bale weigh? #2
10 lbs/cu ft +/- a lot
Guessing your bale at 1200#
/ How much does a round bale weigh? #3
Depends how heavy it is.
Seriously, I'd guess anywhere from 600 to 1200 lbs.
/ How much does a round bale weigh? #5
A 6 by 6 should be roughly of 1800 to 2000 lbs of dry hay with a good baler and operator. Some one with out those options would make it about 1500 lbs.
/ How much does a round bale weigh? #6
<font color=blue>""I just unloaded one from the back of my truck. I was wondering if the weight could be too much for my FEL? "" <font color=black>
If you unloaded it with your FEL, then would you please tell us what happened. If nothing broke, and the rear wheels stayed on the ground, then the weight isn't too much for your FEL, IMO.
If, however, you didn't unload it with your FEL, then I understand the question. What did you unload it with?
/ How much does a round bale weigh? #7
I agree with Art. On a 6x6 bale you're at least going to be 1500lbs. and up to 2000 lbs. With that said I have lifted thousands of this heavy of bales with my JD 4600 loader tractor and not one problem to date.
/ How much does a round bale weigh? #8
I see where TSC has 3 point hitch round bale spears, rated at 1,500#, so I would imagine it is something less than that.
/ How much does a round bale weigh? #9
I always hated those round bales........always had a hard time getting my fingers under the strings and when I picked them up the strings would just about always break.....I always had a hard time getting them up on the back of a pickup....I would rather pick up a square bale any day.../w3tcompact/icons/wink.gif
/ How much does a round bale weigh? #10
No problem if you use several bale hooks. Easier on the hands and gloves too. When the load gets higher a pitchfork Helps.
Egon
/ How much does a round bale weigh? #11
Egon,
I always hated putting them on the hay elevator.....darn elevator could not hardly get the bale up in the barn...bad enough to put them in the manger....had to jump up and down on it to get it to fit..../w3tcompact/icons/laugh.gif
<font color=blue>""I just unloaded one from the back of my truck. I was wondering if the weight could be too much for my FEL? "" </font color=blue>
<font color=red>If you unloaded it with your FEL, then would you please tell us what happened. If nothing broke, and the rear wheels stayed on the ground, then the weight isn't too much for your FEL, IMO.
</font color=red>
Well I did use my FEL with forks to unload the bale. I had to use two chains to stretch around the bale to keep it from falling. It worked well and didn't lift the rear wheels. However, I used the mower (700 lbs) as a counter balance.
I backed down the hill and dropped it right where my wife wanted it.
/ How much does a round bale weigh? #14
There is an article in the "safety forum" about a man getting hit by a 900# hay bale. I would assume that to be a standard size round bale.
/ How much does a round bale weigh? #16
<font color=blue>never attempt to move a bale without either forks or a grapple type bucket</font color=blue>
Scott, I've moved several round bales with my B7100 and even a few with my B2710 using the bucket on the FEL. I just lowered the bucket almost to the ground, eased it up against the bale, then eased forward while at the same time, slowly raising the bucket, and rolled them along until I got them where I wanted them/w3tcompact/icons/laugh.gif No way you were going to pick them up with those little tractors./w3tcompact/icons/laugh.gif
/ How much does a round bale weigh? #17
Perhaps I should have said carry... /w3tcompact/icons/smile.gif
/ How much does a round bale weigh? #18
But you'd better make sure you're on flat land, Bird! I have a friend who moved round bales like that, until one accidently rolled down a hill, and took out part of a fence on the way down!!/w3tcompact/icons/shocked.gif But of course, knowing you, Bird, I'm sure you made sure that there were no hills for it to roll down!!/w3tcompact/icons/clever.gif
/ How much does a round bale weigh? #19
I'll bet that was fun to watch, Rich, as long as you weren't involved./w3tcompact/icons/laugh.gif
/ How much does a round bale weigh? #20
Nope, I wasn't involved!! I've done a lot of dumb things on the farm, but that wasn't one of them!!!/w3tcompact/icons/hmm.gif
But, I sure wish I had seen it happen!! I saw what was left of the fence, and that bale reduced it to splinters!!/w3tcompact/icons/laugh.gif
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A60352)
2013 Chevrolet...
John Deere 6300 (A60462)
John Deere 6300...
2018 HINO CONVENTIONAL TYPE TRUCK (A55745)
2018 HINO...
2011 JOHN DEERE 75D EXCAVATOR (A62129)
2011 JOHN DEERE...
Giyi KH72 QA 72" 4-in-1 Bucket (A60463)
Giyi KH72 QA 72"...
UNKNOWN  500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
