he got a point.
...I to wish that it would have a larger tank but where would they have put it?
The most annoying thing is the way that Kubota has done the fuel gage thingy, I mean that after a full fill up it seems to use no fuel according to the gage, but when the needle just hits the full mark, well after that it dives like an attacking submarine. I do so wish that it would be more accurate.
The problem that you are referring to is hard to fix because if you look at the BX fuel tank it is crammed under the seat with a low point for the pickup and the fuel sender on the left side where the tank drops down. The BX tank stores most of the fuel way above the senders range of travel. Well the fuel sender is going to be a linear device because of the windings but as the tank gets down to the area it worksin it gets small for the last few inches of depth.
I discovered the hard way that completely full is actually overfilled. The main tank on a BX has those "horns" that extend upward and backward to the left and right inside the fenders. If you fill the tank just to the place that the sender registers as full, well, that really is the full level if you want to use the tractor on an uphill slope. If you fill the tank as full as it will go on level ground, then take it onto an uphill slope, fuel will begin pouring from the overflow valve on the left horn of the tank, all over the left rear wheel. In order to work on a slope (any significant slope needs to be uphill, not downhill or sideways), it is necessary to fill the main part of the tank to the place where the sender says full, and not add enough fuel for it to rise into the horns. This gives the fuel somewhere to go without overspilling when the tractor is pointed uphill. Do it this way and you have an even shorter range (timewise). If you're going to stay on flat ground, it's not a problem-fill it into the horns.
