Making My Grapple Better Suited For Loose Wood
   / Making My Grapple Better Suited For Loose Wood #21
Islandtractor
I guess it's a terminology thing..I wanted the grapple to completely close on the bottom edge of the bucket/toothbar...no gaps...with the cylinder at full stroke.I have seen a couple here with a gap between the bucket and bottom of the thumb...didn't want that.
So OVERBITE IT IS....works well for me
   / Making My Grapple Better Suited For Loose Wood #22
What if you put a tooth bar (or even some angle iron) on the tip of the grapple the same width as the bucket?
   / Making My Grapple Better Suited For Loose Wood #23
Thanks nybirdman and IslandTractor for the information. Not meant to disrupt the thread-will PM in the future.
   / Making My Grapple Better Suited For Loose Wood #24
You could use U bolts to clamp a couple if just about any 4 or 5 foot metal bars, pipes or even 2x4s to the top grapple in order to better hold loose brush or fire wood in a bucket grapple. I'd say though that most people just don't find it necessary for brush as it is so tangled and "sticky" that even a narrow upper grapple can hold quite a large load.
1982 GOOSENECK 24FT TRAILER (A52472)
1982 GOOSENECK...
2016 Ford F-550 Altec AT37G 37ft Insulated Bucket Truck (A52377)
2016 Ford F-550...
2007 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2007 DRAGON 150...
2001 INTERNATIONAL 2574 6X4 DUMP TRUCK (A51406)
2001 INTERNATIONAL...
2017 International Distributor Truck (A52377)
2017 International...
2000 Trail King TK70SA-48.2 T/A 43 Ton Hydraulic Slide Axle Step Deck Trailer (A52377)
2000 Trail King...
