Boomer 3040 Tire Chains on Front
   / Boomer 3040 Tire Chains on Front #1
DoubleL
Kempton PA
John Deere 4044R Cab
When I purchased the Boomer 3040 I told the dealer I needed tire chains for a sloped driveway that ices up a lot. He told me a lot of guys are just putting chains on the fronts with good success. That was fine by me since they are much easier to install. They gave me 4 link ladder chains for the fronts. At the time I was not educated on the different styles/types of chains and thought chains were chains and felt comfortable with the dealers advice. :ashamed:
I wish I had 2 links on the front for more grip and less bounce.
Yesterday as we worked the tractor on the driveway the snow packed hard and some ice has setup beneath. I thinking I need them on the back too. Would it be OK to install 2 link ladder chains on the rear or should I just get 4 link ladders to match the fronts ?
Below is a picture of my wife practicing her snow removal skills on a piece of flat road.
   / Boomer 3040 Tire Chains on Front #2
You can use either 2- or 4-link ladder chains on the rears against the 4-link chains you have on front. There is a healthy price difference between the two styles.
   / Boomer 3040 Tire Chains on Front #3
Do you have a weight box for the back or loaded tires. Weight is a tremendous help.
Bill
   / Boomer 3040 Tire Chains on Front #4
Weight definitely is a big plus. Could you buy more cross links and add them to the chains you already have.
   / Boomer 3040 Tire Chains on Front #5
Great picture looks cold :) how did you get her to do it ? take care
Bill
Rear tires are filled with windshield washer fluid. The weight added is about 400 lbs per tire or 800 lbs total. Tires are 17.5-24 added about 50 gallons per tire at 8 lbs per gallon. I understand w/w fluid is the same weight as water and is good to -20F for freezing. Unfortunately the weight doesn't help rubber sliding downhill on ice :(.
Hey never thought about that, good idea :thumbsup:. Where do you buy cross links and what tools do you need. Or better yet does someone have links ?
Thanks, it really wasn't too cold just snowing at about 32 degrees and very little wind. She loves to drive our new toy no problem getting her to drive it. :)
   / Boomer 3040 Tire Chains on Front #7
Hey nice tractor. :laughing: :thumbsup:
I have the same chains on the front and I put duo-grip on the back. They fall between the lugs and I need to modify them. I plan on putting links between the cross links to keep them in place.
Thanks I really like the tractor too.
What blower do you have on the front is it the NH that is blue? That's nice :thumbsup: !
I would like to add a front mount blower next year, whats involved and cost for you was ?
   / Boomer 3040 Tire Chains on Front #9
I can't think of the exact model number but it is the 72" NH blower. The cost.......are you sitting down.........around $7500. That is for the blower and the quick attach bracket. I also got a blade for the front at about $3500. You will also have to have at least one remote if you want the shute rotation and angle to be hydraulic.
I've read front mount blowers are expensive so I didn't fall off my chair. :laughing:
So $7,500 for a front blower, $23,000 for a tractor. I would go as far to guess that profit margins are higher on implements :D
Till I get everything I want it's like I bought a new BMW M series. :confused2:
HELI 5K FORKLIFT (A58216)
HELI 5K FORKLIFT...
1994 Landoll Detach Trailer (A57148)
1994 Landoll...
2011 GALYEAN 130 BBL VACUUM TRAILER (A58214)
2011 GALYEAN 130...
New/Unused SD Lanch 20x20 Carport (A57454)
New/Unused SD...
2017 FORD F550 CAB & CHASSIS (INOPERABLE) (A58214)
2017 FORD F550 CAB...
2023 HELI CPYD25C FORKLIFT (A58216)
2023 HELI CPYD25C...
