Anyway to make my loader lift more
   / Anyway to make my loader lift more
There should be a test port some where on the tractor. ask your dealer and they should be able to tell you where that is. Good luck.
Thanks I will contacting my dealer.
   / Anyway to make my loader lift more #12
When I got my tractor, used, I had the same situation... needed to pick up more but relief valve was popping.
Took tractor to dealer for pressure test...cost $35....they discovered it was slightly under spec...added a shim....now just at high end of spec, barely over. It has made a TOTAL difference in what I can lift... be sure you have sufficient rear weight to balance the front load.
Recommend taking tractor to dealer... will cost you more to purchase the pressure gauge than pay the dealer.
   / Anyway to make my loader lift more #13
I don't believe your FEL valve has work port reliefs, so installing the gage at the input to the FEL valve is a good place to monitor the system pressure and trouble shoot the system.
You dealer probably will not go above the the recommended pressure.
   / Anyway to make my loader lift more #14
In my case, spec is a range of something over 200 PSI... one thin shim (washer) increased pressure from under to just over spec...dealer didn't have thinner washer, left it in.
Looked at the loader control valve and mine has 4 hoses each connected via a quick connect (like an air fitting).
Was thinking of hooking up a pressure gauge to each one and see what I get. I feel this is an accurate test. Is my thinking on the spot or will I need a loaded bucket?
   / Anyway to make my loader lift more #16
Or breaking the front axle housing, blowing tires, destroying bearings. It's hard to tell why the limit was set at 900 lbs., but with wet clay it won't take a lot to reach it.
I moved 150 yards of wet clay last summer with a rear scraper bucket in two days. It's a pain but if you keep at it and don't break the tractor you will get done pretty quickly.
Yes, tire and bearing failures, Plus broken front axles, be careful handling max loads.
   / Anyway to make my loader lift more #17
You could check it there. If your in specs i would leave it alone, if you increase the psi you could start blowing seals and glands in your cylinders.
After reading all your post I see that somebody way smarter than me designed this to carry a certain amount of weight and exceeding this amount can cause serious issues with the tractor and my safety.
I plan on checking the pressure and if it specs out then great. If it is below the specs then it will be sent to the shop for the pros to fix as this is not something I understand and am not comfortable trying to fix.
   / Anyway to make my loader lift more #19
To test the pressure, take a hose off the control valve that goes to the cylinder. Then actuate the valve to pressurize the gage.
You have 2 choices to increase capacity. Bumping up pressure from 2400 psi to 2600 or 2800 will give you a boost and that's about free, shims are cheap and easy to add. It's literally a 5 min task. That will also boost the 3pt capacity a bit too.
The other way to increase capacity is to replace the cylinders with larger diameter cylinders. That's costly as cylinders are about 200-250 each.
Moving larger loads you will be more prone to tipping and potentially faster wear of the bearings etc. You'll need more caution and better maintenance. Spreading the rear wheels to the widest will be helpful and using a larger 3pt weight will be needed to keep the rear wheels down.
   / Anyway to make my loader lift more #20
Ironpig, don't worry, your tractor was designed to be USED. Do it.
Just be sensible.... think for a second about how to baby it when it is under extreme load. Think of your rear wheels as a fulcrum. With lots of weight hanging off the 3ph, you can lift front wheels off the ground, thus no stress on front but all tractor, FEL and 3ph weight is on rear axle. Alternatively, insufficient rear weight and extreme weight in FEL will lift rear and combined tractor and FEL contents weight is on front axle. These are the extremes and of course you don't want either.
So, simply prepare for the load when you are going to do heavy FEL work.
Max pressure in front tires to keep them from rolling off of rims.
Heavy, heavy 3ph counter weight to reduce/avoid strain on front axle and tires. I hang about 1000lbs on 3ph when doing FEL heavy work.
Trust that with hydraulic pressure at high end of spec range the relief valve will protect you from overloading the FEL/hydraulic system.
Go have fun!!
2014 Ford F-150 4x4 Crew Cab Pickup Truck (A55973)
2014 Ford F-150...
Gas Pump Artwork (A55758)
Gas Pump Artwork...
Mini Skid-Steer 4-in-1 Bucket (New/Unused) (A59225)
Mini Skid-Steer...
LOT OF OUTDOOR FURNITURE (A58374)
LOT OF OUTDOOR...
2020 INTERNATIONAL MV607 (A58214)
2020 INTERNATIONAL...
JOHN DEERE 5105M TRACTOR (A58375)
JOHN DEERE 5105M...
