3PTH trailer hitch
   / 3PTH trailer hitch #11
never thought of a chain to limit height. Do you make the chain so short that the 3pth can not go all the way up? Would this cause damage if you moved the 3pth lift lever all the way back? I could see this chain being needed while dumping my trailer, Thanks, Greg
You can set the chain for what ever max height you want, if you are worried about bending your draw bar by lifting against it you could raise the 3 pt all the way up and hook chain there, so it couldn't go any higher.
I hook mine so it can only go maybe 3/4 of it's full travel, if pulling a trailer I don't need it any higher. You can feel the resistance if you pull against it, nothings just gonna snap but you could bend the draw bar by lifting 3 pt if you wanted and the bar was in the outer most position.
But under normal use like trailer tongue rising/bouncing, you wouldn't bend anything.
I see your trailer is quite large, alot longer looking than mine and your axles are farther back than mine also, so maybe yours doesn't come up at the hitch when you dump it? Mine does (forcefully) that's why I said you'd need it for dumping, but for yours maybe not?
I use mine all around the yard, even down steep driveway, I haven't had a problem. But your trailer looks bigger so a couple of things you can do to make pulling it safer, besides the limit chain, if you have 4x4 that would give some engine braking to the front wheels. But if you were really worried about going down a steep hill with a load, then if your trailer has an on board battery break away braking system you could tie a line to that pull out switch and hold on to it in a hairy situation, and if needed you could pull the break away pin for an emergency stop.
You'd have your hands full trying to get out of that predicament once employed, but at least it would bring things to a halt at the moment.
JB.
Like I said before, I am not planning on pulling this trailer with my tractor, other than moving it around on my yard. Even if I did, the land around here is soo flat that it would not be a problem,but you have some good points to keep in mind, Greg
   / 3PTH trailer hitch #13
I've been wondering about the limiter chain also. I was under the assumption the housing the swinging draw bar slides into would break out as its not used for support weight downwards or pull upwards. I dont mind using one myself, but a few family members may use the tractor while I'm gone and Im nervous they will force the 3pt up while chained to the swinging drawbar, Im not sure what to think of the situation. Has anyone thought of using a pulley to cause the upward force of the 3pt either lifting or being forced up by a pushing trailer to pull more in an outward direction of the swinging drawbar? The swinging can take the outward force. I wonder if a pulley coule be used to change the angle of the force from upward force to outward force? Any opinions. ?
   / 3PTH trailer hitch #14
You would have to draw me a picture of that before I could comment.
I understand your concerns about the draw bar mount.
JB.
   / 3PTH trailer hitch #15
Could the original poster, describe how the side pins on the lower cross bar work? Are they in a permanant position or do they slide in and out? I like the simplicity of yours.
   / 3PTH trailer hitch #16
I'm not sure it could be done. I thought about it and there is no where to mount a pulley that would allow the force be changed from up, to a straight backward force. I was thinking maybe mounting a pully on the 3pt hitch you would build, but the pully would go up with the hitch and so the force would still be upward on the swinging drawbar. you cant mount it on the swing either as the force would be upward. no way to do it.....
   / 3PTH trailer hitch #17
You guys are full of good ideas. After reading this, last night, I scored on a $25 Hidden Hitch complete receiver hitch. Gonna use that to build mine.
One question, what do you guys use to cut/drill those 3/4 or 7/7" holes in the mounting brackets? I don't have drill bits that big and no cutting head for the torch.
   / 3PTH trailer hitch #18
I think you meant 3/4" and 7/8" hole. If you have a drill press go to Harbor Freight and get a 1/2" though 1" set of bits for cheap and use plenty of cutting oil and a slow speed. If not for about the same money a machine shop will drill them for $5 per hole.
8 Piece Silver and Deming Drill Bit Set
I bought this set a few years ago and have drilled 100's of holes with no issues but only use them in my drill press and at a slow speed of like 200 rpm or less and use plenty of thread cutting oil from the plumbing section of Lowes.
Chris
   / 3PTH trailer hitch #19
Chris
:laughing: Yea I guess I did mean 7/8". Well, i went out and spent nearly $50 for two drill bits. Crazy. Unfortunately HF is over an hour away. I could go mail order but that's a week's wait. I just looked that set over. I will add that to my wish list. Lots of useful sizes there.
Thanks for the speed advice as well. At these prices I do not want to burn em up.
   / 3PTH trailer hitch #20
I made mine out of an old hitch from a truck, ....
Brandoro,
Do you have any pics of how you mount the hitch to the lower arms? It looks like there is are brackets on the under side of the hitch.
Thanks,
Clem
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
2009 Yamaha Golf Cart (A52377)
2009 Yamaha Golf...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A53473)
GOODYEAR SET OF...
2005 INTERNATIONAL 9400I TANDEM AXLE SLEEPER TRUCK (A54313)
2005 INTERNATIONAL...
2014 VOLVO A25G ARTICULATED DUMP TRUCK (A51406)
2014 VOLVO A25G...
1981 LUFKIN 41 FLATBED (A53843)
1981 LUFKIN 41...
