Double acting cylinder, which port is extend?
   / Double acting cylinder, which port is extend? #1
SteveNH
Member
Southern NH
Kubota BX25, BX1870-1
I was wondering which port on the cylinder is the extend port, I am thinking the cap end? I have a tie rod cylinder for a splitter and I want to try to get it hooked up correctly on the first try. My valve has a detent on the return stroke.
Thanks.
   / Double acting cylinder, which port is extend? #2
It should be opposite of the end the piston comes out.
   / Double acting cylinder, which port is extend? #3
Try to visulize the inside of the cylinder or look for a cross section of a cylinder. Think of the rod end like a donut inside of a paper cylinder. When oil is supplied in one end it will fill the cavity up. That results in the donut being pushed along the tube which causes the rod to extend. If you are going to play in hydraulics you have to see the action in your mind when you put pressurized in equipment.
Craig Clayton
Got it! Thanks for the quick help!
   / Double acting cylinder, which port is extend? #6
I'm new to hydraulics and I tested it with an air hose and air nozzle. Don't know if that was good or bad for the hydraulic cylinder though?
Chad
   / Double acting cylinder, which port is extend? #7
I dont think the air would hurt it Ive done that its sort of scarey as it seems to built up and the bang the rod pops out quite fast....
   / Double acting cylinder, which port is extend? #8
Chad
JUST DON'T USE OXYGEN or you will have a 1 cycle diesel engine
The O2 and the oil in the cylinder under pressure will detonate with the pressure and explode.
tom
   / Double acting cylinder, which port is extend? #9
Yikes, tommu, looks like the entire hyd. manual. Plus, yes a good safety tip on oxygen service.Jy.
   / Double acting cylinder, which port is extend? #10
T56,
Thanks for sharing that link for the hyd. tut. :thumbsup: Much needed here.
2013 Ford Focus Hatchback (A59231)
2013 Ford Focus...
Bobcat A770 (A60462)
2009 Bruton T/A Enclosed Livestock Trailer (A55973)
2009 Bruton T/A...
Jack Daniels Miniature Decorative Truck (A59231)
Jack Daniels...
2017 FORD F-450 XL BUCKET TRUCK (A58375)
2017 FORD F-450 XL...
Club Car Carryall Electric Utility Cart (A55851)
Club Car Carryall...
