Snow Attachments Pushing the tops of bankings ???
/ Pushing the tops of bankings ??? #1
hr3
Mid. Coast Maine
7610 hst
I've searched but haven't found anything yet,,, I'm looking to knock the tops off some of the banking's at the end of the drive,, Getting a bit hard to see out into the road..Bucket won't reach out that far anymore..
/ Pushing the tops of bankings ??? #2
Dig the out the bottom part of the bank and put the snow somewhere out of the way. With the bottom part of the bank out of the way you can then get closer to the top and cut it back.
/ Pushing the tops of bankings ??? #3
As V1 said, dig in at the bottom, and either carry away or ramp it back over the top. I suppose there is still a limit to pushing it back that way tho.
How about a pic of what you are faced with? We like pics and maybe can suggest another alternative.
With the thread title, I thought my wing might help. But it has its limits too. :D
/ Pushing the tops of bankings ??? #4
I spent a couple hours doing just the same this week end and will have to do it again. A short distance but out of the way I tunneld my way a spot to recieve some snow. then about a bucket or two width away I started scooping and moving some snow to my new area. Once I had enough moved to get to the ends I curled the bucket and back dragged the pile to my open area then after a few passe I scoop and move the snow and keep repeating. My drive ends at a very busy street with unforgiving traffic. I must say I didn't put a drop in the street and never had to wait for traffic. It was a PITA mostly because of my equipment limitations. If I had a gy with a pickup & blade helping it would have gone much faster but I did make some good progress doing both sides in about a hour and 1/2.
I would have to take the snow a long way to do most of that,, I was thinking of something like an flat extension on the bucket to push the tops off with.. :confused:
/ Pushing the tops of bankings ??? #6
Do you have room to blow the snow away? If so can you get a blower and knock the piles down and blow them out of the way?
/ Pushing the tops of bankings ??? #7
dynamite
/ Pushing the tops of bankings ??? #8
I used my backhoe once.
/ Pushing the tops of bankings ??? #9
No pics of what you are dealing with? We like pics. :)
Tell us more about the idea you have in mind for an extension.
/ Pushing the tops of bankings ??? #10
Why did you pile the snow that hight to start with???????
/ Pushing the tops of bankings ??? #11
Around here the State Highway Dept uses a pusher on their large Cat loader to push the salt up into the salt shed. Tractor trailers dump the salt close to the doorway or just inside the doorway. The salt shed is 40 feet wide by 60 feet long and 20 feet high to the bottom of the roof trusses. The only way to pile the salt in the shed is by using their homemade pusher. Their pusher is basically a steel flat plow that bolts to the bucket and extends about 10 feet in front of the bucket. The plow blade is about 6 feet wide by 1 foot tall that extends about 10 feet in front of the bucket. Yes, like I said, it is a large loader.
I have pushed salt a few times and you NEED to keep the bucket and the pusher very close to the ground at all times or the rear of the loader will lift off the ground.
I would not recommend even a small pusher extending very far in front of a small tractor.
Finely an answer.. USTA,, do you think a smaller pusher say 4' long by 4' wide would be too much,,???
Ld1 have you ever plowed snow???
Gizmo2,, I was thinking of that as a last resort,, the hoe is in the barn and I haven't been out there in months,,
Beezfun,,, Oooooo I would LOVE to...:D
/ Pushing the tops of bankings ??? #13
If you think that will be long enough it is worth a try. Be careful, even with a little weight 4 feet out front can make the rear tires light enough to lose all traction. The existing snowbank is probably getting hard packed and or icepacked and I wonder if you could move much without a steel cutting edge. Do a test with a snow shovel and you may quickly realize that the pile is not as fluffy as it looks.
I do not know your terrain or options but, If at all possible, I would try to move the pile with the bucket starting at the bottom as suggested by others. Cut a path through the pile to make a path to move the pile back or move the pile to another location.
/ Pushing the tops of bankings ??? #14
Clamp a 2x12 onto the top part of the plow and be done with it. (Although the outrigger plow deal looks very appealing)
/ Pushing the tops of bankings ??? #15
I plow commercially. I usually put in 10-15 hours for even a little 2-3" dusting. So Yeah, I have plowed snow before:D:D:D:D
Maybe that is why I asked. Because I have plowed enough snow long enough to plan in advance.
Like when I plow my drive, and the first snow I push it about 20' back off the drive. Everyone that stops by thinks I'm crazy. But have you ever tried moving back piles in march that have been there all season???? Not easy at all.
I am not trying to insult you or anything, but this is kinda my point. We all learn from experience and from out mistakes. So the question is, do you think you will pile the snow that high next year??? Or will you find somewhere else to go with it?:thumbsup:
Ld1.. :) no insult taken,, and I too push the majority of my snow way back onto the lawn and still have room there,,,The place I'm having the isue is by the end of the drive,, ya know where the town plows keep making it higher at the end of the drive,, Seeing over the bank to check for traffic,,
/ Pushing the tops of bankings ??? #17
When I have to remove high piles, whether with the blower or FEL (I'm about to do that today), I find if you can make a big enough hole in the bottom --don't go in TOO far-- then the top can be pulled down if it doesn't fall by itself. Then remove that, continue inward....
Here's a shot of where I went in through a plowtruck pile, to get at the path to my composter. Used my blower for this. Before & after pics- cut the path through just to the right of the right edge of the "before" pic. You can see the top of the composter box in the background. But-- I'm guessing your piles are higher than mine, so maybe this wouldn't work.....
/ Pushing the tops of bankings ??? #18
Sounds like the problems the same everywhere with the snow banks. We have to use a backhoe on some of the roads because there is only 2-3' on the side of the road before it drops off to over 6-7' and the other side makes up onto a knoll so not much room to move around. You can always just keep digging into it and moving elsewhere with your bucket .
/ Pushing the tops of bankings ??? #19
I plowed commercially for 20+ years and also start with the piles way back off the edge. This year with 7 feet of snow in a month, my piles got to big and started choking the little loop I have in my contractors yard. Had to put the loader on yesterday to punch through to some available areas to load it out.
Mine is at the bottom of a small hill, there was no more room down by the road, so I had to use loader to move that snow back up the driveway and pile it up in the yard.
I call that upper part of my driveway "The Donner Pass" surrounded by 6-8 foot high snow piles, 20 feet deep.
Looks good,
I am seriously looking for a decent used 3pt snow blower. Never needed one before this year, but it would of saved me alot of time/ wear and tear if I had one today.
JB.
1983 INTERNATIONAL S SERIES WATER TRUCK (A57192)
1983 INTERNATIONAL...
PONDEROSA PINE TONGUE & GROOVE (A60432)
PONDEROSA PINE...
2025 LandHonor RB-14-66W 66in Rock Bucket Skid Steer Attachment (A59228)
2025 LandHonor...
UNUSED IRMC HIGH END MASSAGE CHAIR (A60432)
UNUSED IRMC HIGH...
(2) USED 3500 LB TRAILER AXLE W/ BRAKE (A60432)
(2) USED 3500 LB...
DEUTZ MARATHON...
