Oil Filter list
   / Oil Filter list #1
sherpa
North Carolina Mountains
2004 NH TC33D & 2014 NH Boomer 24
I was wondering if anyone has a list of all the different oil filters from all the mfg's that fit their tractor?
I like to keep a list of all the filters that fit my equipment.
I tried to find a conversion table on the internet but they have seem to disappeared.
I have a TC33D and I want to compile a list of all the filters of all brands that will fit it.
Does anyone already have this list?
Thanks,
sherpa
   / Oil Filter list #2
Thanks,
sherpa
I know some may chide me for this, but I have always used a Ford Motorcraft FL-300, and anything that crosses to it, on both my TC40D and 1720. The filter is physically slightly larger, contains more filter surface area, has a anti-drainback valve, exactly the same seal and thread diameter and better pressure rating than the NH filter.
The NH (and probably anything that crosses to it) coincidentally, is the same tiny thing used on the Kohler engine on my lawn tractor.
   / Oil Filter list #4
fram has a good lookup too.. and once you get the fram number.. you can cross that to wix/baldwin/napa.. etc..
soundguy
   / Oil Filter list #5
Sherpa, I've used the WIX reference numbers you posted a long time ago and get all my filters at NAPA. WIX even has the main hydraulic filter and NAPA also carries both my air filters.
Are you looking for some cost savings? The timing for this post couldn't be better since I just spent $248 for my 600hr fluid change...still have to order the PS filter from Messicks though. :(
   / Oil Filter list #6
I too went to all the man. sites and found cross reference for my equip. (Cat, Kubota, NewHolland). Saved an awlful lot of $$s that way. I have two 5 drawer file cabinets full of filters.
I believe WIX and NAPA are the same, WIX being more expensive. Take the leading number off the WIX and you have the NAPA num.
Later,
   / Oil Filter list #7
Thanks,
sherpa
Here's a place to get Wix filters: Filter1 Wix heavy duty engine, oil, automotive, truck, and tractor filers.
   / Oil Filter list
I found one more "engine oil filter" that can be added to the list.
It is a Purolator L35310.
sherpa
Bulk Lot of over 600 NEW Motorcycle Sprockets - 1980s to Present (A61306)
Bulk Lot of over...
2389 (A60432)
2389 (A60432)
flatbed trailer 24ft (A56857)
flatbed trailer...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
2005 Kubota L3130 (A60462)
2005 Kubota L3130...
2003 PETERBUILT PB330 DUMP TRUCK (A58375)
2003 PETERBUILT...
