Cultivator Sweeps: How Sharp is Sharp Enough?
/ Cultivator Sweeps: How Sharp is Sharp Enough? #1
MBDiagMan
Gold Member
Sumner, Texas
John Deere 5045D, Grasshopper 61" with PowerVac,Gator 825i, Cub Cadet 2145
When I was a kid, my Grand Dad had a small forge and anvil that he used mostly for occasional horse shoeing. I also remember him sharpening the sweeps from his cultivator. He sharpened them by heating them red hot and then peening the edges sharp with a hammer and anvil.
When I asked him why he sharpened them this way, and didn't grind or file them, he said that it was because filing or grinding would grind it away, while his method allowed him to get much longer life from the tool.
Now, to my question. How sharp do these cultivator sweeps need to be? I got a two row field cutlivator for use in my garden so I'm not worried about their life. My Granddad cultivated a 120 acre feed patch. I will only be doing a moderate size garden.
If I get them as sharp as a good hoe, will they really do a much better job, or would I be wasting my time?
Thanks for your help and comments.
/ Cultivator Sweeps: How Sharp is Sharp Enough? #2
I'd say your Granddad probably knew exactly what he was doing, why he was doing it, and the benefits. No wasted effort on the farm.
For a garden that you can do and redo often sharp sweeps probably don't make a lot of difference. As you correctly pointed out, a sharp hoe does a better job but a dull hoe does the job - just not as efficiently.
/ Cultivator Sweeps: How Sharp is Sharp Enough? #3
I suspect your grandfather's method also work hardened the tips so they would not wear as quickly. I never remember sharpening cultivator sweeps, but we only farmed about 6 acres of vegetables. I do remember that the sand was very abrasive and erosion was evident on some old sweeps, but it was kind of a self-sharpening process where metal was removed from the top of the sweep as the tip was eroded away, keeping the same thickness at the point.
/ Cultivator Sweeps: How Sharp is Sharp Enough? #4
I grew up farming and we never sharpened a sweep nor did I see anyone else do so. It may work better, but on a large scale, it simply would not be practical.
/ Cultivator Sweeps: How Sharp is Sharp Enough? #5
He couldn't say " If I don't look busy Grand Ma will make me the do the jobs on her list.:D"
/ Cultivator Sweeps: How Sharp is Sharp Enough? #6
Grew up cultivating but have no remembrance of ever sharpening. I do recall doing a complete replacement at the 10 year mark, as I recall.
/ Cultivator Sweeps: How Sharp is Sharp Enough? #7
As the other guys said, I never knew anyone to sharpen the sweeps. I got mine at Tractor Supply Co. and they were never sharpened.
/ Cultivator Sweeps: How Sharp is Sharp Enough? #8
Doc,
I can't really answer your question, but I do clearly remember helping my dad remove the sweeps and taking them to be "sharpened". A local blacksmith would do exactly as you describe: heat red hot then use a hammer & anvil to peen the cutting edges, then quench. We repeated the process periodically, but I don't remember how often, but don't think it was more than once per year - not sure it was that often. As I recall, there was no grinding or fileing involved, just heat/peen/quench.
/ Cultivator Sweeps: How Sharp is Sharp Enough? #9
Sharpening seems recreational i think , i've never heard of it but then sometimes we change them every year the ones following wheeltracks can have no wings left and be just points after a few thousand acres .
/ Cultivator Sweeps: How Sharp is Sharp Enough? #10
I personally believe that the "sharpen by fire" method had a lot more to do with hardening the edges than actually sharpening them.
We farmed as much as 5000 acres for several years when I was a kid and we never sharpened a set of sweeps.
Mark
/ Cultivator Sweeps: How Sharp is Sharp Enough? #11
I discussed this with my uncle, who grew up on a farm had a small farm for several years. He says he never sharpened his sweeps.
However, he does clearly remember having to crank the blower for his dad's forge while he sharped sweeps and plow shares by peening them. He thinks they had to do this in order to get the sweeps to cut vines. Of course they were plowing with mules and working in a lot of "new-ground" in those days. Vines were a particular problem for several years after clearing virgin land.
My dad grew up plowing mules and keep a pair several years after we got a tractor, so it is quite possible this was a common practice with mule-drawn sweeps, ane he just continued to do it with the tractor.
John,
I think you are exactly right. My granddad was born in 1882,drove cattle from Texas to wyoming as a teenager and saved enough to buy his place on the blanco river in Texas in 1910. He did not have a tractor until the late thirties.
When I saw him sharpenig sweeps in the fifties he was using a couple of popping johnnies. The practice probably was a holdover for him. He was a very regimented man.
Thanks for all the replies everyone.
2012 FORD F-350 XL SUPER DUTY CREW CAB SERVICE TRK (A60430)
2012 FORD F-350 XL...
2018 Ram 1500 4x4 Crew Cab Pickup Truck (A59230)
2018 Ram 1500 4x4...
2017 HAMM HD+140I DBL DRUM ROLLER (A60429)
2017 HAMM HD+140I...
2020 CATERPILLAR 303.5E2CR EXCAVATOR (A60429)
2020 CATERPILLAR...
2018 CATERPILLAR 313FL GC EXCAVATOR (A60429)
2018 CATERPILLAR...
UNUSED FUTURE REMOTE CONTROLLED TOY (A60430)
UNUSED FUTURE...
