I could write a book about what I "don't" know about hydraulics, but I think we are discussing something I'd like to do. Add a rear remote so I can change the tilt of a box blade. When I asked my dealer (counter personnel) about it, they were guesstimating that I was looking at $1,500 just for parts.. no estimate on labor.... Folks, are we talking about the same thing?
Doug,
We are talking about the same thing, and so was the dealer. You, like me, have one of the worst-case Kubotas for adding rear remotes. It'd be worth your time to double check if Kubota sells an off-the-shelf "kit" for the
L2800.
I checked with two dealers locally and both said nothing was available for the
L3400, same tractor with a couple more HP. They were willing to gather up all the necessary parts and do the job for me, but the final price would have been close to what you were quoted. Was that for a single remote or a double? It sounds pricey for a single. I don't want to accuse your dealer of anything, but sometimes I wonder if the price isn't directly proportional to how hard it is to do the job yourself.
You'll need most of the parts I listed in one of my earlier posts in this thread.
You have a FEL which makes the process a bit easier, in that you have an easy spot to tap into without fiddling with adapter plates.
If you decide to do it yourself, I'm willing to give you whatever help I can via pics and measurements of the way I did mine. Some are already shown in this thread
TractorByNet.com - Compact Tractor Forum
It's not that hard, really, but you have to design the layout yourself, which is the difference between a ready-made kit and going fully aftermarket sources.
As we've already said a few times, it's not hard to cut the dealer price in half as long as you get it right the first time around. If you have to re-do a few things, it adds up in a hurry. The only real mistake I made was using the wrong cylinder on my rear blade setup, the actual rear remote works great.
One thing about doing it yourself, if you're mechanically inclined but not overly familiar with how hydraulics work, by the time you're done you'll have a much better understanding of it, after a bit of research that is.
Sean
