Grease Fitting Good..but won't take any Grease?!
   / Grease Fitting Good..but won't take any Grease?! #22
AMAZINGLY similar! In fact, I'd say that other than the packaging the only difference is the price.
DW
You never know....these from Northern may just be a cheap copy......the one I use at work is the Alemite brand, cuz it gets used often.....Alemite 339841 Zerk-Mate Grease Fitting / Joint Cleaner, Grease guns, Cordless grease guns, Battery powered grease guns, Grease pumps, Liquid Filled Pressure gauges, Hydraulic pressure gauges, Paintball gauges, Custom pressure gauges, Flashlight, Too
if it doesn't clear the zerk then we pound out the pin, clean up and reinstall.....
the cleaner works sometimes to save labor.....not always.....
   / Grease Fitting Good..but won't take any Grease?! #23
........if it doesn't clear the zerk then we pound out the pin, clean up and reinstall.....
Another though has occurred about using a tool that forces oil through hardened grease: It would seem very likely that if the tool worked as advertised, it might well create a channel/pathway through the hardened grease that would then allow one to force grease into the fitting. All good so far...
What I can see as a potential problem is that this process could well only open up a small passage in the hardened grease, If this were the case, one might think that they were lubricating the whole joint, whereas one might only be only be introducing fresh grease to a small portion of the joint, potentially leading to damage or further damage.
Some fresh grease would of course be better than none, but it would seem that the best solution would be what a professional mechanic would do. To do as you said, and take the whole joint apart, clean and
reassemble.
A good example of "you pay now or you pay more later" in either money or time.
Dennis
2019 Allmand Bros Maxi-Lite II Towable Light Tower (A52377)
2019 Allmand Bros...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
2021 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A52377)
2021 Ford F-250 XL...
2025 Swict 78in Bucket Skid Steer Attachment (A53421)
2025 Swict 78in...
2005 HACKNEY AND SONS, INC. BEVERAGE TRAILER (A53843)
2005 HACKNEY AND...
2006 FORD F-250 (A53843)
2006 FORD F-250...
